A friend of mine gave me this monitor to fix for him. It's a 17” Daewoo L700C LCD with a CML-700C POWER power board.
The problem with it is that it doesn't always work if it gets unplugged from the wall.
When it works, it works fine and wakes up if a signal is fed to it and it can stay on for as long as the signal is present (the only odd thing I can find here is a high-pitched noise when the back light turns on). But when it doesn't work, there's a constant high pitch sound coming from the power supply board and the monitor does not respond to any signal or the power button on the front. Unplugging the monitor and plugging it in a few times can make it work again so I don't think it's an inverter issue. If the monitor has been sitting unplugged for over half hour, it always seems to power up fine the first time. Unplug it and plug it again and it might not work.
I measured the output voltages of the PSU board, and here are the results (the 3.3v, 5v, and 5vsb rails are generated by voltage regulators):
standby ------------ on ----------- not working (dead)
7.61v ------------ 7.61v ------------ 6.36v ------------ 3.3v (supply to 3.3v regulator)
5.52v ------------ 5.52v--------------2.91v ------------ 5v (supply to 5v and 5vsb regulators)
1.03v ------------ 3.29v ------------ 0v ---------------- 3.3v
1.29v ------------ 4.83v ------------ 1.90v ------------- 5v
23.8v ------------ 14.6v ------------ 19.74v ------------ 12v
4.56v ------------ 0.07v ------------ 0.70v ------------- on/off
5.04v ------------ 5.03v ------------ 0.92v ------------- 5vsb
4.86v ------------ 2.14v ------------ 0.88v ------------- BCON
0.03v ------------ 4.54v ------------ 0.05v ------------- BLON
Note that whenever the monitor is not working, the 5vsb is also not present. Also, 12v rail is showing 23.8v when monitor is in standby/off mode! Does this seem normal at all? As far as the PSU design, 12v rail is unregulated and there is no feedback from it to the PWM controller (PWM only gets feedback from the unregulated 5v/5vsb supply rail via optocoupler).
Visually, none of the capacitors look bad (I don't have an ESR meter to test them though). The PSU board does have some serious darkening due to heat near the regulators/rectifying diodes and there are some 85C rated caps in that area. So what do you think is the problem, bad caps perhaps?
By the way, here's a list of the capacitors on the PSU board:
2x Sam Young KMG, 16v, 1000uF, 10mm dia., 17mm h., 105C
3x Samxon GS, 16v, 470uF, 8mm dia., 85C
1x (unknown brand) RMU 25v, 1000uF, 10mm dia., 20mm h., 105C (logo looks like a tree stump)
1x Samxon GS, 25v, 100uF, 6mm dia., 85C
1x Samxon GS, 16v, 100uF, 6mm dia., 85C
1x Samxon GS, 50v, 33uF, 6mm dia., 85C
1x Samxon GS, 50v, 1uF, 5mm dia., 85C
1x Sam Young, 50v, 1uF, 5mm dia., 85C
1x Samxon LP, 400v, 68uF, 25mm dia., 21mm h.., 85C
There are also 2x Sam Young KMG, 35v, 220uF caps on the inverter board. Inverter board is made by PyeounaHwa Electcom, model P1704DA Rev.00. Resistance on HV side on both transformers measures okay (1000 Ohms, ~980 Ohms). No cracked transformer joints.
I didn't mention caps on the video board because they are all SMT and under 100uF (they appear to be Sam Young by the printed logo). There is also no 12v rail going to the video board so I don't think this is the problem either.
If anyone has any other ideas what could be wrong, please let me know. My guess is that caps are the problem here, but I would rather not do a full recap as some of the caps are located right under the heatsinks (though there's probably not much choice here).
Sorry for the long post, by he way.
