Hi i got recently AVR 141, it have two issues one is it going protection mode some times and its surround right channel have volume issue when i am increasing the volume it goes on increasing but suddenly lowering when i reach -42db then it have no change till -28db when reaching --27db it again increasing to a level which is same level of other channel ... i dont know what is causing for this volume issue even i did reset no changes, regarding the random protection mode , i checked the voltage out put at speaker terminal in front right channel its showing around 2.1 volt but other channel shows in milli voltae range so i suspect problem with front right channel. hope it can be fix, but i dnt have any idea about volume issue on surround right channel any one can help me
Harman Kardon AVR 141 protect mode and volume issue
Re: Harman Kardan AVR 141 protect mode and volume issue
hi,,, i want fix the volume issue first , is it problem wit IC njw1197 (dogital volume control ic) only have problem with Right surround, this IC have two unused pins for Surround back channels , but how i can enable this pins to divert audio signal from SB right to this - schematic i attached hereLast edited by srt1; 12-07-2017, 03:24 AM.
Originally posted by Piotr07 View PostTypical "Protect" problem on this model is bad transistors KTC3200 - the differential pair on the Power Amplifier circuit. You must to replace to 2SC1845 of all pair as Q514/519 ,Q818/819 etc.
Originally posted by Piotr07 View PostTry to freeze the differential pair and you will see a change of the DC offset
i need help regarding the volume issue also.. if it faulty NJW1197 ic , i want divert the audio signal to other channel which is unused as this ic has 8 channel volume control is ther now only its 6 channel used ,,hope i can use one channel out of 2 in remaining , but i dont know how to configure it..
Re: Harman Kardon AVR 141 protect mode and volume issue
hi,
i wil try too explain my problem in my best English (i'am from Belgium)
when i switch on my HK VR 141, after few seconds, "protect" appair on the screen and the HK shut down.
someone can tell me the origin of the problem?
best regards
best regards
