Old 01-15-2018, 09:21 PM   #21
FrozenHaxor
City & State: Warsaw
My Country: Poland
Line Voltage: 230VAC 50Hz
Default Re: Alienware M17x R3, LA-6601P is missing +VCC_GFXCORE_AXG CPU voltage
I've found an SLJ4M chipset. Its a QM67, still Cougar Point, I believe it's going to be a better one to test instead of the HM67 currently there.
FrozenHaxor is offline   Reply With Quote
Old 01-16-2018, 02:05 AM   #22
atsio
City & State: Thessaloniki
My Country: Greece
I suppose, yes.
atsio is offline   Reply With Quote
Old 01-20-2018, 02:45 PM   #23
FrozenHaxor
My Country: Poland
PCH changed to QM67. Same behavior.
I have noticed that capacitor PC93 was damaged and measured almost open. Unsure if this was like that before or after the rework. Changed to a good one, no change.
I have a brand new exactly the same KBC on hand, perhaps I could give it a try.
Old 01-20-2018, 11:39 PM   #24
FrozenHaxor
My Country: Poland
After changing the KBC, board behaves in the same way.
Old 01-21-2018, 06:07 PM   #25
FrozenHaxor
My Country: Poland
I've traced the LPC bus lines and wired up my debug card.
Looks like it's not even rolling any codes, does that mean the BIOS is not right?
Here's a quick video of how it behaves:
https://youtu.be/n1eh1221UOY
Old 01-23-2018, 07:31 AM   #26
piernov
City & State: Valbonne, 06
My Country: France
KBC should not be related to this kind of issues except if it disturbs BIOS data lines, but given you get to an S0 state with CPU reset de-asserted it should be fine.
Not having POST codes could mean various things : communication issue between PCH and BIOS ROM, communication issue between CPU and PCH, clock issue, corrupted BIOS, BIOS itself doesn't output any code. You can check the signal on the BIOS CS# pin to at least see if it is being activated.
I've got a older desktop board with the same symptoms, I replaced northbridge/southbridge/clock generator/BIOS ROM/Ethernet IC and it still doesn't want to read the BIOS even though the CPU reset signal is de-asserted.
Not sure what to troubleshoot going from there.
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Old 02-05-2018, 04:24 PM   #27
FrozenHaxor
My Country: Poland
Yeah I recall that I did check the SPI Flash lines for the BIOS and it was talking just fine. Tried 2 more BIOS dumps with no result. I'm stuck at this point.
Old 11-27-2018, 12:53 AM   #28
dg.ott.ca
City & State: toronto, ontario
My Country: canada
you need to check pu800, it makes +VCC, I just fixed similar board (LA-C912P).
often this chip is shorted because of bad caps that fail under heatsink heat. check caps near pu800. Easiest way to locate short, you remove 5V coil by DC input (it will be next to 3V coil, leave that one. remember if shorted 5V line then your coil will be 0V, look up schematics for exact location, its like one coil away from DC jack connector) then measure resistance on each pad. If its 50+ oms/koms then its fine, if low number like 10 oms then you have a short on 5V line. Inject 5V with lab power supply to low resistance pad. Feel mobo for hot stuff, you need at least 2A load to feel heat... or you can crank it to 5A and smell that bad boy!
dg.ott.ca is offline   Reply With Quote
