Good day all,
I did some research on this topic but i cannot get suitable information. Is there a comprehensive web site that has information on SMD LED datasheets.
For example, i have backlight failure on a tv and order the exact same edgelit strip then when i put them in the set and start up the power supply shuts them down immediately. If i fix the old strips then it works fine. If i use a LED tester then if i power a segment (4 x 12) the tester voltage settles down on 40.4V (original) and the replacement strip (44.4V). So that should mean that their forward currents differ. I guess its impossible to know what LEDS the supplier of the back lights used. Communication with chinese suppliers is non existent on aliexpress.
