Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 12-31-2013, 01:41 AM   #21
tibimakai
City & State: Los Angeles/San Dimas, CA
Line Voltage: 120VAC 60Hz
Default Re: Car amplifier(Polk Audio PA660) question
6 FETs not 4.
tibimakai is offline   Reply With Quote
Old 01-16-2014, 12:14 AM   #22
tibimakai
The PA660, it's working great after replacing the two blown final transistors.
Next is the PA880(nightmare) amp.
Need to measure every component and order what I need. I will go with the suggested final pair.
Any recommendation for the FETs?
Old 01-18-2014, 05:38 PM   #23
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
FDP55N06, here's a Mouser link:
http://www.mouser.com/ProductDetail/...252bCTnwymc%3d
"pokemon go... to hell!"
EOL it...
Originally Posted by shango066
All style and no substance.
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 01-18-2014, 07:12 PM   #24
tibimakai
Thank you for that.
I'm buying my parts from Digikey, they have an under $3 shipping option.
They have it too for $1.17/each.
I will ask a stupid question, if I will used these transistors and the other finals that you have recommended, the amp will have more power, or they can just take more punishment?
Old 01-18-2014, 07:49 PM   #25
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
No, it's not stupid at all.
As to the question, the latter applies...
The output power is limited by the supply voltage to the power amp itself. This is set by the ratio of the toroidal transformer in the unit's power supply.
You may notice a few watts output (5-10) more than with original output transistors, since better ones maintain their beta better with increasing (output) current, dropping less themselves and keeping the voltage to the load (speakers) better/higher. IOW, better devices simply maximize what you should've been getting from the unit from the outset.
Depending on the RDS of the replacement MOSFETs in the power supply versus the originals, it is possible for them to run slightly cooler.
But mostly, these little upgrades will make it far more durable and "abuse tolerant," always good for these car amps.
There are 12 resistors associated with those MOSFETs. 6, 10K-47K, from the gates to GND, ensure that any leakage does not allow the MOSFETs to conduct. These are of such high value that a shorted device's backfeed will not destroy them.
There are another six, 4.7-22 ohms, from each gate to its driver. Check all of them for opens, since these will be damaged should a MOSFET backfeed.
Just to be sure, check, with a scope, the drive waveforms before putting the new MOSFETs in.
Replace the fuses with a single 2A fuse, and apply power through a 10 ohm, 20W or greater, resistor. You should see the amp's caps charge up. Normal voltage should be from +/- 65 to 75V. You'll have less than this with the resistor in the 12V supply, but you should still have those two supplies.
You'd want to check this without the 6 power transistors soldered in, for obvious reasons.
I'd also consider replacing those two diodes
Old 01-18-2014, 08:05 PM   #26
tibimakai
Do you mean the double diodes, F182CAI and F182CCI? I can't find any info about them. One is common cathode and the other is common anode.
I have removed the first one and checks out OK. They show weird in circuitry.
I will check out those resistors, some of them(the blackened ones) are even broken off from the soldering. I just hope that I will be able to see there value.
I have started working on this amp now and I'm trying to find out which parts are needed to be changed, to be able to order them.
I have an opportunity to pick up the same set of amps locally(found on Ebay) for $60 both. I may jump on the offer, repair them and sell them.
Old 01-18-2014, 08:31 PM   #27
tibimakai
I also see some ICs, they can't be blown?
Old 01-18-2014, 08:42 PM   #28
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Which ones, in the power amp, preamp, or power supply?
Old 01-18-2014, 08:47 PM   #29
tibimakai
Any one of them, specially the TL494.
Old 01-18-2014, 08:54 PM   #30
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
A scope is your friend...
Old 01-18-2014, 08:57 PM   #31
tibimakai
OK, I will do that. A TL494 is $0.73, I will just get one.
Thank you.
Old 01-18-2014, 11:22 PM   #32
tibimakai
Everything looks pretty good. Two 100Ohm resistors legs are broken off at the through hole, but they all show good values(the ones around the burned FETs).
One suspect transistor I have found which I can't figure out if it's good or bad.
It's a J111 JFET transistor. Between the Drain and Source, I'm measuring 22 Ohms in circuit. I have never dealt with a JFET transistor before. How can I check it out?
8 pin IC is a TL072CN.
Old 01-20-2014, 02:00 PM   #33
tibimakai
Do you think that NTE373/NTE374 is a good choice to replace these 2SC3421/2SA1358?
Old 02-02-2014, 12:41 AM   #34
tibimakai
I have started working again on this amp.
The problem is that I don't know what I'm suppose to do.
I have replaced all the FETs including the JFET. Tested all the resistors arounf the FETs and they all have checked out good. I have also replaced those three 100 Ohm resistors next to the FETs, which looked black.
I have replaced the fuses with 2A once. I have tried with one and it blew it.
I haven't tried with a 10 Ohm/20W resistor though.
The amp started up and it didn't show any protection error.
The finals are not installed yet. Since the PCB is back in it's housing/heatsink I couldn't measure the voltage at the capacitors, but at the pre-finals I'm measuring 60V.
I'm lost with the scope measuring. What kind of signal should I use, where should I measure and on what scale?
Any help would be appreciated.
Old 02-07-2014, 09:45 PM   #35
tibimakai
I have soldered in all the components and all seems fine except the JFET F\J111 which measures 22 Ohm between D and S.
That is normal, or should I investigate more?
I'm about to turn it on and before that I would appreciate any input.
Thank you.
P.S. This is what they say in the datasheet: Static Drain−Source On Resistance at 0.1V, 30 Ohm max.
So it seems fine, no?
Old 02-07-2014, 11:26 PM   #36
tibimakai
I have found a short between + and -.
Need to find out what is causing this short.
Old 02-08-2014, 08:35 AM   #37
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
n-JFET has short when V(gs) = 0V. So that is probably OK.
JFET is a rare device to use nowadays. Only used for high speed or ultra low input current, or maybe to write "JFET Input Circuit" on packaging.
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
Old 02-09-2014, 05:42 PM   #38
tibimakai
It was my mistake.
I have used the wrong screw, to mount the fuses to the front panel. It was to long, and it was touching the positive terminal of one of the fuses.
The amp is working!!
Thank you all, for any help offered.
I have my amps for my car now, I just have to install them.
Old 04-03-2016, 08:46 PM   #39
jakdedert
City & State: Nashville
My Country: United States
I'm a: Hobbyist Tech
Old thread, I know; but thanks all for the info and encouragement. I just picked a dozen of these...mixed PA660s and PA880s. I worked for a small salvage biz a couple of years ago, testing and reworking various electronic returns from a big-box electronic store. These were left over, and I just happened to run into the owner the other day and asked about them. I've only pulled one 660 apart, and it's got toasted outputs, of course. They got so hot some of the foil traces on the board lifted.
I'll do inventory (I don't even know how many of each I have yet) and testing over the next few weeks. Back when I was doing it, some of them worked, others failed in protection, others were totally DOA.
Should be fun....
jakdedert is offline   Reply With Quote
Old 04-04-2016, 09:57 PM   #40
jakdedert
Inventory shows nine PA660 and two PA880. I have a PA330 in my van bridged mono for subwoofer power. It's basically half of a 660, two channels with the same specs as the 660. It's been a very stable and solid amp for two years. I'm thinking about swapping that out for a 660, and the owner wants one of the 880s if I can fix them.
Next step is to set up a test rig and start checking them.
