The model of this 500W ATX PSU is "Cooler Master rs-500-psap-j3".
It appears that after an estimated 30,000 hours of mostly uninterrupted usage, its output power peak dropped below the minimum required to keep my computer on.
Diagnosis: the PSU ran stable w/o issues for a few years permanently attached to the same PC hardware (PC #1). All hardware remained the same up to several months before the PSU failed. I found my PC abnormally powered off without any UPS event recorded; this occurred again after ~12 hours of uptime since the previous abnormal shutdown; this second time I inspected the PC and it wouldn't complete the boot due to sudden power off _after_ POST; a few attempts later the computer stopped POST-ing at all. It remained like that since. I replaced the PSU with a new one — a same power 500W PSU, branded — and PC runs fine. Testing again with the old PSU doesn't produce POST. Testing the same old PSU on a much less demanding PC (PC #2) works fine.
It appears that after sustained usage, my PSU suddenly and rapidly lost its power capacity.
Hardware description:
PSU Inspection:
The PSU PCB appears perfect n the components side: no bulging or leaked caps, no discoloration due to heat, no cooked glue, all normal at sight. I measured the two large (1W ?) resistors on the lower right corned of pic #1: they are within ~7 percent tolerance, but they have a gold tolerance band (5%). I didn't unsolder them to take the measure, so the rest of the circuit might have interfered.
Then I flip the PCB: the tracks side of the PCB doesn't show any overheat discoloration, but there is an abundant solid deposit more or less around all capacitors' pins, so I suspect capacitors could be a culprit. The deposit is abundant also around the two primary 680uF caps and around the yellow parallelepiped on the bottom of pic #1 (a capacitor?). So I bought ~13 € of capacitors and replaced all caps circled in red in pic #1, excluding the yellow thing that I couldn't undoubtedly identify (pic #7).
There is also minor deposit on the tracks side of the vertical PCB mounted on the main PCB, too. I didn't work on that.
Recapping:
I replaced the caps circled in red on primary and secondary sides:
The non-circled cap in the middle of the picture appears to be connected to 5V or 3.3V rail; I couldn't cheaply buy a matched replacement for this one.
Results:
After recapping, the PSU continues to behave as described above under "PSU inspection": it still works fine under minor loads, but fails to boot the same PC that used to run for years.
Notes: all pictures taken after PSU was serviced.
- PC #1: The PC on which this old PSU was mounted on is a dual Xeon workstation with presumably high power drain.
- PC #2: The smaller PC I used to test if the PSU worked at all is a very small Pentium 3 or 4 which works fine on its own with a 300W unbranded Chinese PSU.
PSU Inspection:
Recapping:
Results:
