hello everyone i am currently working on a vizio jv50phdtv10a with power supply aax30284301. for some reason when i test to voltages at the connectors all of the 5v supplies are putting out .81 volts instead of 5 volts. the p.o. attempted to replace the caps on this board and im pretty sure caps 285 and 287 are wrong, if anybody knows the values of those caps and any ideas as to why the 5v connects are only reading .81 volts that would be great. thank you in advance.
vizio 50in plasma psu problem
Re: vizio 50in plasma psu problem
What makes you think the caps are wrong? post some pictures so we can see what you are talking about.
The 5 volt standby comes from T501, the smps ic is U501, What voltage do you have across C522? You should have about 160v dc, If you have 160v, unplug and check the resistance of R510, if it is open, U501 is bad.
C287 is 470uf likely 25v C285 could be around 100uf or less likely 25v alsoLast edited by R_J; 09-12-2018, 10:37 AM.
So you are getting RL-ON voltage from the main????
The 5V standby that supplies the main board, and runs the processor, when you push the power button the processor outputs a logic level to RL-ON, that turns on the power supply and THEN you get the other voltages like the 9Vsc, 5Vsc etc.
Once you have those you will get the VS-ON conmmand from the main to turn on the VS & VaLast edited by R_J; 09-12-2018, 02:05 PM.
It could be that the RL-ON line needs to be taken low to turn on the power supply.
If you disconnect P800 from the main is the RL-ON still high? if it is take it to ground, you should here the relay turn on.
The section of the power supply that gives you 5Vsc comes via D271 from the secondary of T112, for T112 to operate requires U151 and Q151 to drive it. Which requires voltage that is across C603, which comes from D101 bridge rectifier, The ac for the bridge is fed via RL102 and the two green thermistors TH102 and TH101, which will get shorted by relay rl101.Last edited by R_J; 09-12-2018, 02:46 PM.
sorry for the delay, i had some time to mess with the set again and you were absolutely correct, when p800 to main is disconnected the relays click on. so something on the main is stopping the psu from powering on? i have had a case with this set before where the main would keep blowing up. the set would run for 10 minutes or so and then no sound and no picture.
