Asus X555LD rev: 3.6
    Hi. Liquid contact product. I can't find out what they are.
    Re: Asus X555LD rev: 3.6
    Not sure what you mean exactly ? And the first image is of horrible quality...
    Do you mean the values of the components? or What the components actually are?
    The other images show clearly what the components are... They are prefixed with Letters.
    Here is a list from Adie Dkhaz:
    COMPONENTS CODE
    KODE HURUP KOMPONEN
    C :CAPASITOR
    D IODA
    F :FUSE
    L :INDUKTOR
    PC :POWER CAPASITOR
    PD :POWER DIODES/DIODA
    PL :POWER INDUCTOR
    PQ :POWER TRANSISTOR
    PR :POWER RESISTOR
    PU :POWER INTEGRATED CIRCUIT
    Q :TRANSISTOR
    R :RESISTOR
    T : Transformers
    U :INTEGRATED CIRCUIT/BGA CHIP/EMBEDDED CONTROLER/BIOS IC,ETC
    X : Terminal strips, terminations, joins .oscilator
    Y : Crystal
    ABBREVIATION ON LAPTOP MOTHERBOARD DAN SCHEMATIC
    AC : Alternating current
    ACDRV : AC adapter to system-switch driver output
    ACEDET : Adaptor Current Detector
    ACGOOD : Valid adapter active-low detect logic open-drain output
    ACIN : Adaptor Current sensor Input
    ACN : Adapter current sense resistor
    ACOP : Input Over-Power Protection
    ACOV : Input Overvoltage Protection
    ACP : Adapter current sense resistor, positive input.
    ADP+ : Adapter Positif Suplay
    ADP_ID : Adapter Identity
    AGND :Analog Ground
    ALWP :ALWAYS ON POWER
    B+ : AC OR BAT POWER RAIL FOR POWER CIRCUIT
    BATT : Battery
    BAT+ :BAT POWER RAIL FOR POWER CIRCUIT
    BAT_DRV :Bat Fet Gate Driver
    BAT_V Battery Voltage
    BOM :BILL OF MATERIAL MANAGEMENT
    BT :BUTTON
    BT_EN :Bloototh Enable
    BUZER :Connected
    BYP :Baypass
    CHGEN : Charge enable active-low logic input
    CIN : Input Capacitor
    CLK_EN :CLKOCK ENABLE
    CN :CONECTOR
    CRT :Cathode ray tube
    CSIN :Current Sensor input Negatif
    CSIP :Current Sensor input Positif
    DC irect current
    DM IM/DIM SOCKET/SOKET MEMORY/SOKET DDR
    DOCK OCKING SOCKET
    EC :Embedded Controler
    EC_ON :Embeded Controler Enable
    EMI :Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK)
    EN :ENABLE
    ENTRIP :Enable Terminal
    F :FUSE
    FSEL : Frequency Select Input.
    GATE : Trigger gate
    GND :Ground
    GP :GROUND PIN
    GPI :General Power Input
    GPIO :General Power Input Output
    HDMI :High-Definition Multimedia Interface
    ID :Continuous Drain Current
    IDM :Pulsed Drain Current
    IIN : Operating Supply Current
    IIN(SHDN): Shutdown Supply Current
    IIN(STBY): Standby Supply Current
    IS :Continuous Source Current (Diode Conduction)
    IVIN :Battery Supply Current at VIN pin
    JP :JUMPER POINT
    KBC :Keyboard Controler
    LCDV :LCD POWER
    LDO :Linear Driver Output
    LGATE : Lower-side MOSFET gate signal
    LPC :Low Pin Count
    LVDS :Low-voltage differential signaling(SYSTEM PENSIGNALAN)
    MBAT :MAIN BATTERY
    NB :North Bridge
    ODD :OUTPUT DISC DRIVE
    PCI :Peripheral Component Interconnect
    PGOOD : Power good open-drain output
    PIR :PRODUCT IMPROVED RECORD
    PSI# :Current indicator input
    PVCC : IC power positive supply
    RSMRST : Resume Reset
    RTC :REAL TIME CLOCK
    SB : South bridge
    SHDN :Shutdown
    SYS_SDN :System Shutdown
    SPI :Serial Peripheral Interface
    TD eath Time
    THRM :THERMAL SENSOR
    TMDS :Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY)
    TP :TES POINT
    TPAD :THERMAL PAD
    UVLO : Input Undervoltage Lock Out
    V :RAIL(POWER)
    V+ :Positive Voltage
    VADJ : Output regulation voltage
    VALW :ALWAYS ON POWER
    VALWP :VALW PAD
    VBAT :BATTERY POWER
    VCCP :power chip(ich,graphic chips)
    VCORE :POWER PROCESOR
    VDD : Control power supply
    VDDR :POWER DDR (VDRAM/VRAM/VMEM)
    VDS :VOLTAGE DRAIN SOURCE
    VFB : feedback inputs Power
    VGS :VOLTAGE GATE SOURCES
    VIN : Input Voltage Range
    VIN :ADAPTER POWER SUPLAY(vol_in)
    VL :Power Lock
    VL :voltage across the load/Tegangan beban resistor
    VL :Voltage Linear
    VLDOIN :Power supply of the VTT and VTTREF output stage (to powerMOS).
    VOT :Volt_out
    VRAM :Power Memori
    VREF :POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
    VS :SUITCH POWER
    VS+ :SUPPORT VOLTAGE POSITIF
    VSB :POWER SWITCH BUTTON
    VSS : Signal ground.
    VSW :POWER SWICT
    VTT : Memory Termination Voltage
    VTERM :Memory Termination Voltage
    VUSB :POWER USB
    VGA :POWER VGA (VGPX/VGPU/VCVOD)
    VGFX :POWER GRAPHIC CHIP
    VREF :VOLTAGE REFERENCES
    while alive { live(toFullest=true) }
      tankyou
        thanks MJ-meo-dmt
          Yes I could not find the values of the components. 3 PCS ( 1 pcs C / 2 pcs PR )
            Well its difficult... What I would do is either just take a chance and use components from a donor board from the same region (Around the EC) or I would go and find the pins or circuit those components are in and then research through that EC Datasheet typical example circuits to see what they used, and or I would go and research similar models or motherboards and see what they used in those circuits as those components... Its up to you xD fun fun fun....
            Goodluck
              The picture you posted at post #5 is from chinafix, i noticed the jumpers soldered together. This post on elvikom may help you in this area (use google translte) https://www.elvikom.pl/asus-r556l-pl...9q-t53939.html
              Are the 2 resistors and cap you need damaged .
                Thank you.
