Hi. Liquid contact product. I can't find out what they are.
Asus X555LD rev: 3.6
Re: Asus X555LD rev: 3.6
Not sure what you mean exactly ? And the first image is of horrible quality...
Do you mean the values of the components? or What the components actually are?
The other images show clearly what the components are... They are prefixed with Letters.
Here is a list from Adie Dkhaz:
COMPONENTS CODE
KODE HURUP KOMPONEN
C :CAPASITOR
D IODA
F :FUSE
L :INDUKTOR
PC :POWER CAPASITOR
PD :POWER DIODES/DIODA
PL :POWER INDUCTOR
PQ :POWER TRANSISTOR
PR :POWER RESISTOR
PU :POWER INTEGRATED CIRCUIT
Q :TRANSISTOR
R :RESISTOR
T : Transformers
U :INTEGRATED CIRCUIT/BGA CHIP/EMBEDDED CONTROLER/BIOS IC,ETC
X : Terminal strips, terminations, joins .oscilator
Y : Crystal
ABBREVIATION ON LAPTOP MOTHERBOARD DAN SCHEMATIC
AC : Alternating current
ACDRV : AC adapter to system-switch driver output
ACEDET : Adaptor Current Detector
ACGOOD : Valid adapter active-low detect logic open-drain output
ACIN : Adaptor Current sensor Input
ACN : Adapter current sense resistor
ACOP : Input Over-Power Protection
ACOV : Input Overvoltage Protection
ACP : Adapter current sense resistor, positive input.
ADP+ : Adapter Positif Suplay
ADP_ID : Adapter Identity
AGND :Analog Ground
ALWP :ALWAYS ON POWER
B+ : AC OR BAT POWER RAIL FOR POWER CIRCUIT
BATT : Battery
BAT+ :BAT POWER RAIL FOR POWER CIRCUIT
BAT_DRV :Bat Fet Gate Driver
BAT_V Battery Voltage
BOM :BILL OF MATERIAL MANAGEMENT
BT :BUTTON
BT_EN :Bloototh Enable
BUZER :Connected
BYP :Baypass
CHGEN : Charge enable active-low logic input
CIN : Input Capacitor
CLK_EN :CLKOCK ENABLE
CN :CONECTOR
CRT :Cathode ray tube
CSIN :Current Sensor input Negatif
CSIP :Current Sensor input Positif
DC irect current
DM IM/DIM SOCKET/SOKET MEMORY/SOKET DDR
DOCK OCKING SOCKET
EC :Embedded Controler
EC_ON :Embeded Controler Enable
EMI :Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK)
EN :ENABLE
ENTRIP :Enable Terminal
F :FUSE
FSEL : Frequency Select Input.
GATE : Trigger gate
GND :Ground
GP :GROUND PIN
GPI :General Power Input
GPIO :General Power Input Output
HDMI :High-Definition Multimedia Interface
ID :Continuous Drain Current
IDM :Pulsed Drain Current
IIN : Operating Supply Current
IIN(SHDN): Shutdown Supply Current
IIN(STBY): Standby Supply Current
IS :Continuous Source Current (Diode Conduction)
IVIN :Battery Supply Current at VIN pin
JP :JUMPER POINT
KBC :Keyboard Controler
LCDV :LCD POWER
LDO :Linear Driver Output
LGATE : Lower-side MOSFET gate signal
LPC :Low Pin Count
LVDS :Low-voltage differential signaling(SYSTEM PENSIGNALAN)
MBAT :MAIN BATTERY
NB :North Bridge
ODD :OUTPUT DISC DRIVE
PCI :Peripheral Component Interconnect
PGOOD : Power good open-drain output
PIR :PRODUCT IMPROVED RECORD
PSI# :Current indicator input
PVCC : IC power positive supply
RSMRST : Resume Reset
RTC :REAL TIME CLOCK
SB : South bridge
SHDN :Shutdown
SYS_SDN :System Shutdown
SPI :Serial Peripheral Interface
TD eath Time
THRM :THERMAL SENSOR
TMDS :Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY)
TP :TES POINT
TPAD :THERMAL PAD
UVLO : Input Undervoltage Lock Out
V :RAIL(POWER)
V+ :Positive Voltage
VADJ : Output regulation voltage
VALW :ALWAYS ON POWER
VALWP :VALW PAD
VBAT :BATTERY POWER
VCCP :power chip(ich,graphic chips)
VCORE :POWER PROCESOR
VDD : Control power supply
VDDR :POWER DDR (VDRAM/VRAM/VMEM)
VDS :VOLTAGE DRAIN SOURCE
VFB : feedback inputs Power
VGS :VOLTAGE GATE SOURCES
VIN : Input Voltage Range
VIN :ADAPTER POWER SUPLAY(vol_in)
VL :Power Lock
VL :voltage across the load/Tegangan beban resistor
VL :Voltage Linear
VLDOIN :Power supply of the VTT and VTTREF output stage (to powerMOS).
VOT :Volt_out
VRAM :Power Memori
VREF :POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
VS :SUITCH POWER
VS+ :SUPPORT VOLTAGE POSITIF
VSB :POWER SWITCH BUTTON
VSS : Signal ground.
VSW :POWER SWICT
VTT : Memory Termination Voltage
VTERM :Memory Termination Voltage
VUSB :POWER USB
VGA :POWER VGA (VGPX/VGPU/VCVOD)
VGFX :POWER GRAPHIC CHIP
VREF :VOLTAGE REFERENCESwhile alive { live(toFullest=true) }
Well its difficult... What I would do is either just take a chance and use components from a donor board from the same region (Around the EC) or I would go and find the pins or circuit those components are in and then research through that EC Datasheet typical example circuits to see what they used, and or I would go and research similar models or motherboards and see what they used in those circuits as those components... Its up to you xD fun fun fun....
Goodluckwhile alive { live(toFullest=true) }
Originally posted by ismailakyoltr View PostYes I could not find the values of the components. 3 PCS ( 1 pcs C / 2 pcs PR )
Are the 2 resistors and cap you need damaged .Last edited by SMDFlea; 11-14-2018, 09:13 AM.
Originally posted by SMDFlea View PostThe picture you posted at post #5 is from chinafix, i noticed the jumpers soldered together. This post on elvikom may help you in this area (use google translte) https://www.elvikom.pl/asus-r556l-pl...9q-t53939.html
