I needed a 20-pin ATX power supply to power an old P4 motherboard and IDE hard drive combo but I did not have any good ones to use. What I did have was a stack of bad ones that I got for learning and experimenting with so I settled on trying to repair a Bestec ATX-300-12E.
I chose this supply for several reasons. The most important being it met my primary criteria, but it had a few other things that interested me in this supply. All but one cap looked good from a visual standpoint and the 5vsb not only worked it was powered by a Viper22A which I am very familiar with but was my first time seeing one put in a power supply by a manufacturer. In the past, all the supplies I have repaired required a recap before troubleshooting could even be started, with this supply I could fix it first then, decide if it was worth a recap.
This supply uses a TPS3510 supervisor chip and a UC3842B PWM chip. I had the 5vsb voltage like I stated previously and I had PS_ON# but when this was grounded I would get nothing. I found the UC3842B was shorted out so I replaced it. I tried it again and no response. I then found a shorted Zener (ZD1) and after I replaced it still no response, the UC3842 was not getting its' Vdd. The transistor Q2 turned out to be the final culprit preventing the supply from working.
The recap was fairly simple but the glue they use is madding. This supply had three CrapXon capacitors, the two main ones and one on the 5vsb. The one on the 5vsb was the only popped cap in the entire supply. There were two KZE that I did not replace but everything else had to go. I luckily had some Chemicon main caps from a supply I was getting parts from to replace the CrapXon ones this one had in it. The rest of the caps I had on hand in my new stock.
The final picture I have attached shows the output voltages of the power supply. I put a 20 ohm load on the 12V, a 10 ohm load on the 5V and I did not load the 3.3V output. I was very pleased that I was able to find what was wrong with this supply all by myself, and then to scrounge all the parts I needed to get it working again. Anyway, if you have read this far I hope I have not board you to death with my post, thanks for reading.
