Re: Samsung LN46D630M3F, TV powers on, sound works but no backlight
As you can see, the circuit is very sensitive (Triming the 38.8K with 2M resistor) and they set the output Voltage by trimming the Total resistance of two resistors, so as long as you get the output Voltage to be around 380~390V range then you will be OK, i would try to get the resistance toward higher Value than lower value. What is the next up value of 38K 1% available at digikey?
