I have this mini 250w PSU that comes from a MSI Hetis G31 barebone.
The problem started with lockups during windows login until the computer would not start at all. The PSU started but the power led from the motherboard was blinking.
I removed the psu and tested it. It switched on whith eratic voltages and shuted down after a bit. Upon inspecting the PSU all of the secondary capacitors were buldged so i replaced them all. All of them tested with zero capacity. Two of them where reported as diodes by the tester.
Now the computers switch on and seem to have good voltages however without load. If i connected a hard disk the PSU starts power cycling again. With out a hard disk i can boot windows from a a usb hard drive without problems. Also the is a small tickling sound coming from the psu. It was much louder before replacing the caps.
Any ideas what to look next?
