I have a Marantz SR4320 receiver and it has a very distorted and garbled right channel. Where might I start looking for issues and/or can someone walk me through troubleshooting this thing? Somehow missed this on the first quick pass lol but I have found A problem and hopefully THE problem (See pics).
Marantz SR4320 very distorted channel
Re: Marantz SR4320 very distorted channel
Originally posted by R_J View PostIt almost looks like something was spilled in that area, try replacing the burnt resistor, check the transistors in that area, like Q318 etc.
You can test them in circuit, if they check shorted or maybe not right, then remove & test them out of circuit, you can also compare the reading with the same transistor in the working channel.
Have you tried just replacing the resistor to see if it works, Just keep an eye on it when you turn on the amp, if the resistor starts to smoke, check for shorted transistors.Last edited by R_J; 12-18-2017, 05:49 PM.
Originally posted by R_J View PostYou can test them in circuit, if they check shorted or maybe not right, then remove & test them out of circuit, you can also compare the reading with the same transistor in the working channel.
Originally posted by AsRock View PostThat dark crap what i think it is ?, isn't that the stuff that goes conductive ?, if so might be under the cap(s) too.
As an update; replaced the resistor and pulled the transistor but it checked good out of circuit. Just need to get some mica transistor insulators and I'll have it back together.
Looks like R352 burned up. 100R 1/4W. That is the for the -ve rail for the right channel power amp driver and voltage amp stages.
I would expect other resistors like R348/R346 100R to also burn up.
Shorted C314 is the only thing I can see that would cook just this one part.
Originally posted by redwire View PostLooks like R352 burned up. 100R 1/4W. That is the for the -ve rail for the right channel power amp driver and voltage amp stages.
Originally posted by R_J View PostThey are not that bad, and not the cause of the problem. most caps like that are 20% tollerance. and they are not new so they may check a bit low, change them later if you like.
Have you tried turning on the amp after replacing the resistor?
Got the board along with new Mica strips and ceramic thermal compound installed.
Good news: the new resistor didn't smoke and seems to be doing just fine.
Bad news: I have next to no output from headphones or speakers, I get a very quiet output when the volume is all the way up and that's it. confirmed the issue is present on channel a and b left and right and on multiple inputs and tuner. seems I might have goofed something else up?
HAHAHAHA I fixed it, APPARENTLY These jumpers HAVE to be installed to get any sound!!!
Works awesome now!Last edited by Wehan; 12-21-2017, 01:38 PM.
Originally posted by Wehan View PostGot the board along with new Mica strips and ceramic thermal compound installed.
Works awesome now!
Been there done that with the jumpers lol, Good to hear you fixed it.
