This is my son power amp in his car this amp is a little over a year old
This just start a couple a week ago this —>
The amp work for about 5 minuets then the red LED light comes and is in protection mode
The switching power supply has no problem right now powering the amp Putting out 10 amp
I ran the amp with sub only then rear only then front only and when I got to front only at very loud play with the amp taking maximum from my 10 amp switching power supply that I had posted because it was having problems
https://www.badcaps.net/forum/showthread.php?t=72557
The two caps that are marked with red circle are the caps that when pushing 10 amps start to get very warm
The four caps that are marked green circle get a little warm when pushing 10 amp
The four big caps marked in blue also get a little warm when pushing 10 amps
The 6 device that are on the heat sink gets a little warm when pushing 10 amps
What brand and series of caps should I put in this amp
The caps that are getting very warm are the caps that might be put it in the protection mode
Because as soon as you turn the volume down and pull less amperage the caps cool down very quickly
