Re: Sharp LC 60LE655U 2 long flashes + 2 short flashes
I don't think your measuring the gate, likely the drain and it could be that your meter is picking up the high frequency pulse from the circuit.
That is the pfc circuit, and it IS working.
I can't remember but did you ever check the voltage on PC7601 opto, pins 3 & 4 are on hot side, 1 & 2 on the cold side, check in standby, then check them with power on. Its about the only thing left that could be shuting down the circuit
On the cold side of PC7601 is the 13.2v-ovp circuit, which could shut down that part of the power supply.
I guess you could check all those diodes, including D7131, in the seconday of that T7601 transformer, just make sure none are shorted, D7131 might show low, .2-.3 in diode test as there are 2 diodes in parallel and are likely shotkey type
