PASSWRD Dell Latitude 5510 FDW50 LA-J381P
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #61
    Re: PASSWRD Dell Latitude 5510 FDW50 LA-J381P
    Originally posted by xxxxRobertxxxx
    Looks like it's time for new programmer. I think I go for TL866II as veryfication failed on both apps.
    Yes TL866II is a good choice for the money.
    Edit: I'll also suggest to get another adapter, for example:
    https://www.badcaps.net/forum/showpo...&postcount=228
    Become a Badcaps supporter
    Thanks to all supporters.​
      • 22109
      Have you done the voltage mod,that can make it a bit more stable
      https://www.youtube.com/watch?v=-ln3VIZKKaE
      https://www.youtube.com/watch?v=HwnzzF645hA
      • xxxxRobertxxxx
        • May 2022
        • 12
        I just purchased TL866II and awaiting for delivery. I also ordered new adapter.
        Thank you for all your help so far. I come back as soon as I receive programmer and read the chip properly.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #64
          It is not a question of voltage modification, but of a specific unit in hand. This junk is unpredictable at work, I had a unit that unmodified worked very well even with 1.8v chips, and another piece (of junk) did the same problems as most of them do.
          To take the risk of working with this on a laptop that costs more than £600 second hand is, to put it mildly unreasonable.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #65
            Good decision, the only reasonable one in this case. Send me a message when you're ready because I'm not always here, and I'll be happy to help you, we'll remove the password without any problems, don't worry.
              • 22109
              I agree,but most folk will not pay for a better more expensive programmer. Sad buts thats how it is,and you know we`ll see a lot more corrupt backups being posted until another programmer is released thats just as cheap or cheaper but more reliable hardware and software wise.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                I completely agree, but in this case it is an expensive machine, and luckily I happened to be around and guessed what could happen, because the events could have turned out much worse - you know very well what a pain is to rebuild the bios for this particular machine, in addition all members here receive absolutely free of charge help to solve their problem thanks to our work and knowledge. Certainly from the money saved, at least they can afford to buy a better tool, which they will use in the future anyway.
                • xxxxRobertxxxx
                  • May 2022
                  • 12
                  Hi there,
                  I just received my new programmer today and couldn't wait any longer to read BIOS chip from my dell 5510. I think I've improved reading 100%. as the programmer does the really good job. I have done 3 undependent BIOS dumps as you have advised to do. Please have a look when you got a minute.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #69
                    Hi there,
                    Indeed, completely different story this time - the new programmer works as it should.
                    Below is your unlocked file, at first boot enter the bios and write the Service Tag, then restart and you're good to go:
                    • xxxxRobertxxxx
                      • May 2022
                      • 12
                      Thank you very much for such a quick response. I will programm asap and let you know about result. Do I need to erase the chip before applying new BIOS or just overwrite it?
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #71
                        Old content must be erased first.
                        • xxxxRobertxxxx
                          • May 2022
                          • 12
                          Laptop is dead. I don't have time to reverse it now. I have a look tomorrow. do you have any suggestions?
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #73
                            Should work, most probably you didn't programmed the chip properly (with verification) or didn't solder the chip as it should.
                            Try again.
                            https://www.badcaps.net/forum/showth...41#post1139941
                            • xxxxRobertxxxx
                              • May 2022
                              • 12
                              I just come back from work. I'm going to give it another try today and let you know. I'm going to desolder the chip, clean the pads, put new tin and reprogram the chip ones again. I'm sure that the report I have received from Xgpro stated that everything went right but I know that sometimes things are going wrong and the best way is to start from the begining and this is what i'm going to do. I also can confirm that verrification has been done after re-programming the chip and was showing success. I know it's sounds odd but this is what happend.
                              Thank you very much for all your support and your knowlage.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #75
                                Exactly.
                                About the verification part - do not rely on a automatic verification process built into the software. I've said it before on another occasion, but here it is again for your information:
                                The safest method for verifying the contents is to read the chip after programming and compare the resulting file with the source. This eliminates any doubt, and you can proceed to soldering the chip to the board.
                                In this way, each step of the process is verified, and in the event of a problem, only the last step can be checked - namely the soldering to be inspected.
                                Otherwise, everything has to be done again from the beginning, because it is not certain at what stage the mistake was made.
                                This also applies to the initial reading of the chip with the original (containing the password) dump. Two or three content dumps need to be made that are compared to each other. If they are the same then it is certain that the content has been read correctly.
                                The procedures described above can take five minutes longer, but save five hours of headaches.
                                • kaseak
                                  • Nov 2021
                                  • 9
                                  • uk
                                  #76
                                  hi guys is possible to find a passwd for dell latitude 5510
                                  security code :51N60F3-8FC8 THANKS
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #77
                                    https://www.badcaps.net/forum/showpo...&postcount=135
                                    • JJong
                                      • Apr 2021
                                      • 19
                                      Please unlock my bios password.
                                      • aldopc
                                        • Jul 2017
                                        • 477
                                        • Chilito
                                        #79
                                        Try and comment the result please
                                        • JJong
                                          • Apr 2021
                                          • 19
                                          Power does not turn on.
                                            DELL Latitude 5510 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5510 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5510 boardview and 5510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5510...
                                            09-06-2024, 09:10 PM
                                            09-07-2024, 02:20 AM
                                            09-07-2024, 12:10 AM
                                            09-06-2024, 10:20 PM
