sony vaio mbx 266 schematic needed
Re: sony vaio mbx 266 schematic needed
MBX-266 Sony schematic :
Attached FilesComment
Dear guys
i have same board with dead condition after installed OS so any solution kindly advice.Comment
what do you mean dead condition? No power? if you can go to CMOS settings your laptop or PC is working 80%.
if its a software issue. re install it again or install software OS that works recently.
Never stop LEARNING because life never stops TEACHING!Comment
Please help boardview for mbx 266 Z50CR S1202-2. Thanks in advanceComment
hi
As mentioned in prev posts , no schematic for this board but closely relatedLast edited by stingerchamp; 10-04-2020, 07:13 AM.Comment
SONY MBX-266 schematic (close related) attached
SONY MBX-266 schematic attachedComment
try this
i personally checked ICs numbers match with Z50CR MBX-266 motherboard and their location is same .Comment
In sony vaio laptops mostly 5v/3.3v power supply controller RT8223M gets a hit.
https://datasheetspdf.com/datasheet/RT8223M.htmlComment
Need Sony Z50CR MB S1202-2 MBX-266 Schematic Please
Hi friend i need schematic for Sony Z50CR MB S1202-2 MBX-266 motherboard
in which am not getting backlight laptop is working fine
i check backlight fuse which is ok. am in confusion. any solution will be appreciated.
thank youComment
Pl find attached herewith the schematics for MBX 266 wistron Z50RComment
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
Sony Vaio PCG-NVR23 MBX-67 D9JK653JU4NE4 Laptop Schematic...
Channel: Schematics and Boardviews
11-06-2024, 05:50 AM -
Sony VAIO SVF153 Series DAHKDAMB6A0 Laptop Schematic
SVF153B1YM
SVF153B1GN
SVF1532APXB
SVF1532ACXW
SVF153A1YV
SVF15328SGB
VJF153F11X
SVF1532P1RB...-
11-06-2024, 04:38 AM -
Sony Vaio VPC-CW MBX-226 Laptop Schematic
M9A0...-
11-06-2024, 03:39 AM -
Sony Vaio VGN-P Series Laptop Schematic
Foxconn MBX-187...-
11-05-2024, 07:42 AM -
- Loading...
- No more items.
