C46_ lenovo_la-3691p bios requreid
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    I have required bios bin file
    C46_
    IHL00
    LENOVO_LA-3691P
    rev:1a
    2007-06-01
    BIOS REQUREID
    CHIP SET IS
    NORTH=LE82GM965
    SOUTHNH82801NHBM
    PROCESSOR=INTEL
    I/O=ONE KB926QF B1
    MAKE=LENOVO
    MODEL= AS PER SEARCH ON NET, NOT WRITTEN ON LAPTOP (
    MODEL NAME= 2049
    SOME WHERE WRITTEN ON LAPTOP BOTTOM IS lenovo3000 G410
    LAPTOP POWER UP FOR ALMOST 4SEC THEN OFF, NO DISPLAY AT ALL
    ALWAYS VOLTAGE
    5V=5.1V AT PL2
    3.3V=3.4V AT PL3
    POWER UP VOLTAGE : DURING ON CONDITION AFTER PRESSING POWER BUTTON IS
    1.5V AT PL6
    1.8V AT PL5
    1.1V AT PL 4
    0.0V AT PL 1 DUE TO NO BATTERY INSTALL
    VCORE AT CPU =0.9V PL9, PL10,
    pl sugest what to do,
    thanks in adavance
  • hbissou
    • Mar 2015
    • 11
    • morocco
    Re: C46_ lenovo_la-3691p bios requreid
    hi , try this
    • sanehdeep2012
      • Oct 2013
      • 139
      • india
      thanks for so fast reply,
      I will try and revert back soon
      • sanehdeep2012
        • Oct 2013
        • 139
        • india
        SORRY
        after flashing bios provided by you (hbissou) laptop continuous on without pressing power button, fans also spin in starting then fan stop but laptop on continuous on, processor also heat so processor is working,
        can some body help me on this topic ,
        I also read the original bios files it is size is approx. 1mb, and provides bios size is 2mb is it is correct
        • nazrul145
          • Jan 2014
          • 337
          • BD
          Try this one..
          • sanehdeep2012
            • Oct 2013
            • 139
            • india
            thanks nazrul145,
            for your support, and given file , I will try soon and revert back
            • sanehdeep2012
              • Oct 2013
              • 139
              • india
              thanks nazrul145 for providing bios , but system shows same symptom , when press power button , laptop on for 4~5 sec then goes off,
              CHIP SET IS
              NORTH=LE82GM965
              SOUTHNH82801NHBM
              PROCESSOR=INTEL
              I/O=ONE KB926QF B1
              MAKE=LENOVO
              MODEL NAME= 2049
              ALWAYS VOLTAGE
              5V=5.1V AT PL2
              3.3V=3.4V AT PL3
              1.5V AT PL6
              1.8V AT PL5
              1.1V AT PL 4
              schematic is attatched , pl any body help what to do,
              if any body have
              power sequence (required)
              board view (required)
              for the same will be appreciable,
              thanks
              • sanehdeep2012
                • Oct 2013
                • 139
                • india
                dear friends pl reply if any body face same problem or having thre required
                power sequence and board view of
                lenovo3000 G410IHL00
                LENOVO_LA-3691P
                rev:1a
                2007-06-01
                BIOS REQUREID
                thanks friends
                • sanehdeep2012
                  • Oct 2013
                  • 139
                  • india
                  friends pl reply if any body have the reqreuid
                  power sequence
                  board view for
                  C46_
                  IHL00
                  LENOVO_LA-3691P
                  rev:1a
                  2007-06-01
                  BIOS REQUREID
                  CHIP SET IS
                  NORTH=LE82GM965
                  SOUTHNH82801NHBM
                  PROCESSOR=INTEL
                  I/O=ONE KB926QF B1
                  MAKE=LENOVO
                  MODEL NAME= 2049
                  ALWAYS VOLTAGE
                  5V=5.1V AT PL2
                  3.3V=3.4V AT PL3
                  1.5V AT PL6
                  1.8V AT PL5
                  1.1V AT PL 4
                  • sanehdeep2012
                    • Oct 2013
                    • 139
                    • india
                    pl help any body
                    • Ramee
                      • Jul 2014
                      • 218
                      • Israel
                      Make sure you have 3v on bios ic.
                      • sanehdeep2012
                        • Oct 2013
                        • 139
                        • india
                        bios ic voltage
                        1.3.42v
                        2.0.9v
                        3.3.42v
                        4.0
                        5.0
                        6.0
                        7.3.42v
                        8.3.42v
                        • sanehdeep2012
                          • Oct 2013
                          • 139
                          • india
                          if i flash bios with bios file provided by hbissou then laptop continue on but no display,
                          • Ramee
                            • Jul 2014
                            • 218
                            • Israel
                            Even on external monitor no display? Check the panel, cable and voltages coming out from the cable.
                            • sanehdeep2012
                              • Oct 2013
                              • 139
                              • india
                              no display in enternal or external ,
                              this is faulty releated to bios or south bridge might be,
                              so i need power sequence and board view
                              • Marc97
                                • Jan 2016
                                • 189
                                • Phillipines
                                i already experienced same issue same model,,, mine was fix,, ill just try replace bios IC write it to new IC
                                • Marc97
                                  • Jan 2016
                                  • 189
                                  • Phillipines
                                  Originally posted by marc97
                                  i already experienced same issue same model,,, mine was fix,, ill just try replace bios ic write it to new ic
                                  bckup
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • cr4zychriss
                                    by cr4zychriss
                                    • Rebrand: PC Specialist
                                    Today, 04:04 PM
                                  • pirati
                                    by pirati
                                    10-27-2025, 04:20 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
