help repairing Gigabyte gv-n105toc-4gd
  • klendatu
    • Mar 2022
    • 45
    • france
    hi
    im looking for people who have the gv-n105toc-4gd gigabyte
    to look for those components
    shematic and boardview welcome
    need to know those values
    c 671 678 684 693 815 825 824
    r 634
    ty
    Last edited by SMDFlea; 03-28-2022, 05:48 AM. Reason: Renamed thread title from "help repairing"
  • benwaterson
    • Aug 2008
    • 202
    • United Kingdom
    Re: help repairing Gigabyte gv-n105toc-4gd
    Capacitors should be 0.22u 6.3v on the pcie lines
    Are you sure it's r634? Looks like c825 that's missing on the 2nd image or is r634 open circuit?
    • klendatu
      • Mar 2022
      • 45
      • france
      thanks
      ure right but wanted to know the value just to test and verify...
      825 is missing
      possible same value than 824 ?
      will change the 3 capacitors
      wanted to change them but my iron heater is not adapted too
      so i wait my air thermal to do the job
      • benwaterson
        • Aug 2008
        • 202
        • United Kingdom
        This boardview should work
        • klendatu
          • Mar 2022
          • 45
          • france
          hi
          im really glad
          as i suposed same model except ram values
          normally got all to maintain it !!!
          • benwaterson
            • Aug 2008
            • 202
            • United Kingdom
            Yeah, that circuit looks identical
            • klendatu
              • Mar 2022
              • 45
              • france
              hi
              ty again
              just a question how to identify by see the value of voltage of cms capa ?
              must find replacement on "giving cards"
              • benwaterson
                • Aug 2008
                • 202
                • United Kingdom
                If it doesn't say then you need to guess from the circuit that they are part of and allow some room for error - what voltages are expected on the inputs etc.
                For instance, C825 shows as being connected to 12V_EXT6 and GND, so the cap needs to at least work with 12v (so aim for 16V)
                • klendatu
                  • Mar 2022
                  • 45
                  • france
                  well ty for answer but wasnt the point of the question lol
                  how to reconize a 6.3v than a 16v cause no marks on it ?
                  just the size ?
                  other question is what temperature components supports ? i suppose heavy ones not to burn on rohs....
                  and should be high cause made on ceramic
                  in other hand what temperature ti use to dismount them by air and what on iron to mount them
                  ty
                  • benwaterson
                    • Aug 2008
                    • 202
                    • United Kingdom
                    Ah sorry, I misunderstood.
                    If you are pulling components from another board then it would be helpful to have a schematic for that board as well, otherwise its hard to know.
                    • klendatu
                      • Mar 2022
                      • 45
                      • france
                      thanks...
                      they could do differents colours !!!!
                      i recover comonents from many boards....from differents functions.... so dont have any shema
                      other question
                      does c674 678 684 693 missing makes the pc unbootable ?
                      this card is strange...
                      no booting pc but if u does it by motherboard chipset u can turn it on by windows perephicals (dismount and remount)
                      my daughter said she saw like a flash gpu side and near outputs...
                      i suspect her adaptor hdmi->vga to had a pb and makes a component blow
                      l19 seems to get hot
                      and c822 seems to have a crack on it
                      will try a photo
                      • klendatu
                        • Mar 2022
                        • 45
                        • france
                        here they are
                        • benwaterson
                          • Aug 2008
                          • 202
                          • United Kingdom
                          perhaps a short on q13 or q14
                          • klendatu
                            • Mar 2022
                            • 45
                            • france
                            r7093 et 7094 are fine
                            i will dismount l19
                            when i mesure between the 2 sides goes 1 execpt at 1 point goes 0
                            think maybe the solder broken at 1 side
                            it will explain the flash...
                            • klendatu
                              • Mar 2022
                              • 45
                              • france
                              maybe ure right the 6508 seems to get hot
                              some marks around
                              gonna do a picture to get your pov
                              continuity around l19 and c822 seems ok
                              will redo solder for L19
                              • klendatu
                                • Mar 2022
                                • 45
                                • france
                                q13
                                how may i verify it ?
                                • nvidiauser
                                  • Mar 2022
                                  • 7
                                  • Madrid
                                  Hi!
                                  I´m try this boardview but isn´t valid to my graphic card.
                                  I have gv-n105tg1 4gd.
                                  Some parts are similar, but the part I need is not quite valid.
                                  In my case, the fans and the fan stop led do not work.
                                  Is it possible to get the board view?
                                  Thanks!
                                  • klendatu
                                    • Mar 2022
                                    • 45
                                    • france
                                    Originally posted by nvidiauser
                                    Hi!
                                    Thanks!
                                    hi
                                    otherhands does the card works ?
                                    if it does u can try to reflash the card...
                                    did u try msi afterburner and try to use your own def for fans ?
                                    • klendatu
                                      • Mar 2022
                                      • 45
                                      • france
                                      Originally posted by klendatu
                                      q13
                                      ok found how to test it
                                      so ive got 1.3Mo beetween 3-4 pins
                                      so the mosfet is good
                                      am i right ?
                                      im quite sure the unworking of that card is only missing capa at pcie rail.....
                                      just waiting a capa test to find some to put in place
                                      • klendatu
                                        • Mar 2022
                                        • 45
                                        • france
                                        q14 got 1.7Mo
                                        • pastapoulos
                                          Repairing GIGABYTE RTX 3070 TI GAMING OC 8GB Rev.1.0
                                          by pastapoulos
                                          I picked up this non-working graphics card with the intent of repairing it. I don't know the details of its failure, but the card is in near-perfect cosmetic condition. It had never been opened before I started working on it.
                                          During my inspection, I didn't spot any obvious physical damage. However, when testing, I discovered the PCIe 12V line was open. I replaced the blown fuse and rechecked the measurements—no short circuits on the main lines.
                                          When I tested the card in a system, it prevented the PC from booting. I checked the main voltages,...
                                          11-22-2024, 08:57 AM
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • nikovmiroslav
                                          Gigabyte A5 X1 Need Bios
                                          by nikovmiroslav
                                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                          Gigabyte A5 X1
                                          From motherboard:
                                          S/N: 1TNH55ER1350895
                                          P/N: 6-77-NH55ERQY-D02-2CGB
                                          On sticker from the back of the laptop:
                                          S/N: SN21351J000657...
                                          08-24-2025, 09:15 AM
