dell inspiron 5458 dead after shut down
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    hi everyone can help me please about the problem of this DELL INSPIRON 5458 laptop turns on and boots fine if cmos battery removed and put it back.but when i shut down the laptop cannot turn on again dead i need to pull out the cmos and put it back again to turn on.what could it be the problem with this anyone help me on this please. thanks in advance
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: dell inspiron 5458 dead after shut down
    any help on this please laptop turns on and works fine if i removed cmos battery and back it again but when laptop shut down i cannot turn on again unless i removed again the cmos
    • karim011
      • Nov 2016
      • 122
      • Morocco
      check 3.3V & 5V Present on mainbaord
      • String2016
        • Nov 2015
        • 2238
        • philippines
        i have the same issue also with this motherboard coils near cmos battery have and volts and near graphics have 3.3v but the rest no voltage. and removing cmos battery and put it back and measured again when multimeter hit the coil near memory laptop turns on but after charger plugged out cannot turn on again unless i remove the cmos
        • String2016
          • Nov 2015
          • 2238
          • philippines
          im trying to find a solution but still the same issue with this laptop
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            i also noticed that when i plugged in the battery charger light present but cannot power on even i removed the cmos and put it back but without laptop battery turns on when cmos battery remove and put it back what could it be the problem with this laptop
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              i update the bios with latest version still the same issue i need to remove the cmos and put it back to start the laptop i cmos remove 5 short beeps can anyone advise to fix this issue please
              • lorins_core
                BlackSmith
                • Dec 2012
                • 552
                • Philippines
                Friend do this first. may be have short on terminal of cmos. recheck. trace on this area some caps have leak not shorted.
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  thanks for the response i have attached the image near cmos and mark the coil and capacitor that has 0v
                  • ramneb
                    • Sep 2017
                    • 3
                    • Philippines
                    it could be, there is a short circuit on it, try replace cmos battery, see what happens,
                    ( (IT Technical Support)
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      i already tried replaced new cmos battery and still the same issue laptop works fine once it boots the only problem when i shut it down dead again cannot turn on i need to remove the cmos battery and put it back in order to turn on
                      • Romulo
                        • Nov 2016
                        • 484
                        • Philippines
                        update: ill try to replace cmos battery with low voltage 1.1v it gives 5 short beeps error but i can turn on many times even if i shut it down and turn on again give 5 short beeps and then it takes around 20 seconds to display and boots fine
                        • alvin24705
                          • Dec 2015
                          • 16
                          • Indonesia
                          can u show the pic of model MB ?
                          • alvin24705
                            • Dec 2015
                            • 16
                            • Indonesia
                            check RTC_AUX_S5 (SRTC_RST#,RTC_RST#) signal without turn on (only use adaptor)
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              Dell inspiron 5458 AAl10 La-B843P 1.0 laptop working fine now if i put low voltage of cmos 1v but have 5short beeps battery but when new one 3v can turn on but after shut down cannot turn on again need to remove cmos first in order to turn on again
                              • alvin24705
                                • Dec 2015
                                • 16
                                • Indonesia
                                im glad for you laptop if already can running, but if u want to be a normal laptop u can repair the RTC signal. that's signal for RTC battry (Cmos)
                                • Romulo
                                  • Nov 2016
                                  • 484
                                  • Philippines
                                  how to fix the issue for this because if i put low voltage 1v cmos battery it keeps short beeps 5 times how to fix this rtc signal please
                                  • Romulo
                                    • Nov 2016
                                    • 484
                                    • Philippines
                                    anyone have a schematic for this model to check the rtc signal please
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      first you have to find the schematics file and upload it here.
                                      then remove the main battery and connect a good CMOS battery.
                                      then shutdown the laptop and press the power button.
                                      If it does not turn on, measure all important points throughout the motherboard to find which voltage line is wrong.
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        i dont have schematics for this can someone have this please share. i already tried new cmos battery the problem is laptop turns on but after i shut down cannot turn on again but when i insert low voltage cmos battery i can turn on the laptop and when i shut down i can turn on many times but the problem is laptop beeps 5 short
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
