Magnavox 32mf231 LCD after replacement of 3 caps Screen Flickers once pluged to power
  • vafghan20
    • Feb 2011
    • 11
    Hey guys, i am new to the forum have an issue with this 32 inch Mangavox LCD tv. Before repair TV screen backlight would flicker once or twice when you plugged it into a power outlet and then it would be dead. Took it apart and saw 2 caps vented on the Power supply and decided to replace three Cap's two that were vented and the other because of its location and size. After the replacement of the three cap's the screen flickers continuously like an old florescent lamp trying to light up. The TV has an led next to the power switch which never comes on in any color and never did since i have been working on this tv. The power button on the front has no effect on the flickering of the screen only when you plug it to an outlet is when you can stop or start the flicker of the screen. The Power supply board number is "3138 103 6282.1". Can somebody tell me if i put the right series caps on the Power supply. Do the small caps on these power supply go bad also and would it cause this symptom?
    Images show the Power supply and what type of caps i replaced
    Any input would be great.
    thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: Magnavox 32mf231 LCD after replacement of 3 caps Screen Flickers once pluged to p
    thanks
    Good job of documenting what you have done. The Panasonic NHG was a poor choice for this application. A Panasonic FM or FR would be the proper choices.
    PlainBill
    • vafghan20
      • Feb 2011
      • 11
      Thats great thanks PlainBill, i am going to order the right cap for this tv and get back to you guys on the results.
      • flavious27
        • Jun 2011
        • 10
        Hey I have the same set, 32" magna, same caps failed. Have you gotten yours up and running again?
        • gorr35
          • Nov 2010
          • 127
          Do you plan on letting us all know the results?
