Need schematic HannStar J MV-4 94V-0 0737
  • killersoft
    • Apr 2017
    • 75
    • algeria
    Hello gays,
    Please I need the schematic of the motherboard HannStar J MV-4 94V-0 0737
    Thank you
  • killersoft
    • Apr 2017
    • 75
    • algeria
    Re: Need schematic HannStar J MV-4 94V-0 0737
    Picture of MB
    • piernov
      • Jan 2016
      • 4439
      • France
      This is not the motherboard model number, this is some kind of generic label.
      What's the computer? Take high-res picture of both sides of the board if you can't find any references.
      • killersoft
        • Apr 2017
        • 75
        • algeria
        True
        It is icw50 la-35819
        • piernov
          • Jan 2016
          • 4439
          • France
          Compal LA-3581P? Schematics attached, but don't waste your time on this laptop. It has got an MCP67 which is defective (NVidia chip from 2007).
          • killersoft
            • Apr 2017
            • 75
            • algeria
            Thank you my friend...but there is no 19Volt in PQ12 (4407) so Vin on this mosfet is 19volt and Vout is 1.87 i'll try to change it
            • ghjchano
              • Jun 2022
              • 1
              • Veracruz
              Re: Need schematic HannStar J MV-4 94V-0 0840
              Please I need the schematic of the motherboard HannStar J MV-4 94V-0 0840 pleas.
              Thank you
              • piernov
                • Jan 2016
                • 4439
                • France
                https://www.badcaps.net/forum/showthread.php?t=88758
                HannStar don't design boards, they manufacture the PCB. "J MV-4" and "94-V0" are not board model numbers, they are generic markings about PCB characteristics.
                • emp.raouf
                  • Feb 2022
                  • 1
                  • algeria
                  Have YOU the SHMATIC OF HSB E89382 MV-4 94V-0 PLZ
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                  • atunguyd
                    Acer x163w Monitor PSU schematic
                    by atunguyd
                    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                    03-05-2025, 02:08 PM
                  • Thetechdude
                    MSI Ventus RTX 4080 16G Broadview schematic needed
                    by Thetechdude
                    Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                    I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                    Thanks.
                    07-15-2025, 11:15 AM
                  • ianpoultonknights
                    Zenbook Flip 15 UX562AI schematic
                    by ianpoultonknights
                    Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                    06-26-2025, 02:41 PM
                  • Adv10119
                    Need help please! schematic for LA-9982P rev 3.0 (A02)
                    by Adv10119
                    Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                    I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                    I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                    01-31-2024, 01:18 AM
