I have been given an acer 5920g with a problem , When you plug the jack in the power adapter led blinks. I know this is a common problem with some acer models , has anyone dealt with these power issues .
acer 5920 g blinking power adapter
Re: acer 5920 g blinking power adapter
Hello, i've 2 motherboard's with those problem and one was the PC112 shorted, the other was a short on PC90.
After capacitor's replacement one of the motherboards is working great, but the other one only boot's after 6 retries.
When pw button pressed, the motherboard come and go for 6 times and then it boots fine and works perfectly.
If i shutdown or restart, then again only boot's after 6 retries.
Do you have any ideia of what may be causing this delay ?
RegardsComment
That does not makes sense for modem module, many notebooks have it optioned in or out but this Acer, I don't like that when it fusses about that. I usually take modem out to save on complexies and slightly save on power.
Cheers, WizardComment
Acer Aspire 5732Z dead
Hi
Please help me out i have acer aspire 5732z its dead power jack is ok,
Silence Like Dreams
You are great!!! I solved my issue.
But now i have another prob. with another 5920g and because you are so
qualified i would ask you some tips.
The problem is that notebook seems to start normally but nothing is displayed on video. (but i can ear windows welcome sound and i can connect to the notebook with remote desktop). I also tried to change video cards but nothing (the same video cards work on another 5920g). I also tried to connect external monitor but nothing no image come out.
Can you give me some help?Comment
Thanks to you guys i was able to localise the bad caps PC112 PC118 and PC90 on the motherboard of my Acer 5920g.
After removing them everythings seems to work fine (Green LED on the PowerSupply doesn flash anymore and the Blue LED on the Laptop is working).
Now i want to know if i can run the laptop without those caps, or does i have to replace them before using the laptop?
On the follwing pages they are telling that the are "redundant":
http://www.fixya.com/support/t280473...or_green_light
http://www.fixya.com/support/t338288...tor_fix_doesnt
http://www.fixya.com/support/t899162...ot_power_power
Thanks in adavance for your help.
GreetingsComment
Don't take advice from fixya.Mann-Made Global Warming.
- Dr Seuss
Ok.... thanks for your warning!
I found those old articles from google...
Those articles just helped to localise the badcaps....
Can i test the laptop without those smd caps PC112 PC118 and PC90.
Or does i have to replace them? What about the values? I seems that my local dealer dont has exactly the same caps!
Thanks again in advance for your help!Comment
I wouldn't turn it on with missing parts unless you've traced the whole circuit and know it's okay.
If you are in the US check digikey.com and mouser.com.Mann-Made Global Warming.
- Dr Seuss
Those capacitors are grounded, they mostly serve as a drain or filter to the parasite electricity around processor supply circuit. Although you won't have a problem leaving without them, it's not recommended. I can't remember right now but I guess they are 100uF 25v. Need to confirm.Comment
Like this.
http://search.digikey.com/scripts/Dk...=490-5308-1-ND
If those are in/near CPU socket they are probably across Vcore and used to filter RF noise [higher frequencies than ripple that come from EMI sources like CRTs, WIFI, Cell phones, electric motors] out of the power to the CPU.
[Desktops have these too but few people realize it. - Some processors put them on the CPU instead of in the socket.]
There are typically something like 10-20 [+] of those in parallel.
You can verify that's what they are by finding a bunch of others in parallel with them by doing continuity checks using a DMM.
If there are a bunch of good ones in parallel then leaving a few out for a short time shouldn't hurt anything as long as you stay clear of EMI sources, but I wouldn't leave it that way permanently.
.Last edited by PCBONEZ; 06-12-2011, 04:21 PM.Mann-Made Global Warming.
- Dr Seuss
This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 06:00 PM
This specification for the HP ProBook 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 640 G5 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...09-06-2024, 12:00 PM
This specification for the HP EliteBook x360 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 830 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-06-2024, 12:00 PM
This specification for the HP EliteBook 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 1050 G1 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...09-06-2024, 12:00 PM
- Loading...
- No more items.
