Asus UX31E rev 3.2
  • pimoz
    • Dec 2020
    • 8
    • Slovenia
    Asus UX31E rev 3.2
    Hello!
    Well, my baby old ultrabook died. I was changing the thermal paste and after puting it back together it wont work anymore.
    The ultrabook is Asus UX31E board revision 3.2.
    If I plug in the AC it turns on by itself. Fan spins, power led is on but nothing on the screen. Same with external VGA and HDMI. If I try to force shut it down (5s power key) it just turns on again.
    If I unplug AC and have it run only on battery it stays off. I can get power led and fan working by pressing power button. No screen however.
    I tried looking at power flow. I get all rails except VGFX_CORE which has 0V.
    PL8003 coil measured good. I'm guessing the problem is RT8166. Or could it be the mosfets driving VGFX_CORE?
    Otherwise the board looks ok and nothing is overheating or smoking.
    In attachment you'll find schematic diagram and fz file.
    Please help, I'm really not able to buy a new computer right now (corona and economic situation)
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Asus UX31E rev 3.2
    Try first an hard bios reset. Remove the bios battery short the bios battery for 5 sec. Then place everything back. If this doesn't work . Make a picture in harddefenition from voltage on every coil. Then remove power. Then resistance value from every coil to ground.
    Good luck
    Best regards
    Steve
    • pimoz
      • Dec 2020
      • 8
      • Slovenia
      What do you mean short the bios battery? Do you mean short the battery itself or the pins on the motherboard to which the battery is connected? What good would shorting the battery do?
      Here are the resistance and voltage values from coils:
      PL8800 146.7 kohm (jumps around untill going still); voltage goes from 10V to 16V then back down
      PL8100 9.16 kohm; 3.369 V
      PL8301 0.466 kohm; 1.508
      PL8101 5.56 kohm; 5.07 V
      PL8400 388.6 ohm; 1.806
      PL8200 35.6 ohm; 1.066 V
      PL8003 17.5 ohm; 2 mV
      PL8700 70.4 ohm; 0 V
      PL8005 20.5 ohm; 0 V
      When measuring resistance ac, battery pack and bios battery were plugged off.
      Thank you for looking into this
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        You have power sequence available at page 4 of schematic
        Check pm_rsmrst# signal
        Check all signals from 1 to 18
        • pimoz
          • Dec 2020
          • 8
          • Slovenia
          All signals from 1 to 18:
          3VA_EC 3.298V
          EC_RST# 3.268V
          VSUS_ON 3.295V
          ME_SusPwrDnAck 3.357V
          SUS_PWRGD 3.290V
          PM_RSMRST# 3.273V
          ME_AC_PRESENT 3.294V
          PWR_SW# 3.291V
          PM_PWRBTN# 3.294V
          ME_PM_SLP_M# can't find it
          PM_SUSC# 3.356V
          ME_PM_SLP_LAN# can't find it, maybe SLP_LAN# 3.357
          PM_SUSB# 3.355V
          ME_SLP_M_EC# can't find it
          SUSC_EC# 3.284V
          SUSB_EC# 3.284V
          ME_+VM_PWRGD can't find it
          ME_PWROK can't find it
          SYSTEM_PWRGD 3.326V
          Where I wrote I can't find it, it means i can't find it in FZ file (maybe some other name?)
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Every signal is generated hmm
            Have you checked flashing of bios
            Do you have 3v at bios chip, when you press power button what is voltage on power button when you press it, does it go down to 0
            Have you tried hard reset as suggested above?
            Remove rtc cell from motherboard while in cold state without adapter and without main battery and other device such as WiFi card SSD drive etc.
            Press power button 30sec and release
            Put back rtc cell after 30min
            Shorting means in cold state with twizer or wire
            Connect rtc cell section positive terminal to ground or negative terminal for few seconds but make sure no power attached
            • pimoz
              • Dec 2020
              • 8
              • Slovenia
              Yes, 3V at bios is present.
              Yes, power button pulls down to 0V.
              Hard reset was done, no change.
              I removed everything except fan and laptop screen.
              I will look into reprogramming bios.
              The weird thing is that motherboard powers up when plugged into ac by itself. And even if I try to force shutdown holding power key for 5s, when i release it powers up again.
              Any other ideas? VGFX_CORE is still the only power rail not comming up.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                Flash good bios
                Rsmrst# voltage must be 3v
                Did you check ram section?
                If ram section ok then we check for gfx
                • pimoz
                  • Dec 2020
                  • 8
                  • Slovenia
                  Ok I will reflash good bios.
                  How do i check ram section?
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    I have created a thread for it for DDR 3, DDR 3 L, DDR 4
                    https://www.badcaps.net/forum/showthread.php?t=91082
                    • pimoz
                      • Dec 2020
                      • 8
                      • Slovenia
                      My baby is saved!
                      I've connected the bios chip to raspberry pi via spi and reflashed it. It now works
                      For reference i'm attaching bios file. https://www.badcaps.net/forum/showthread.php?t=91316
                      Thank you very, very much Wish you a merry christmas and a happy new year
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        Congratulations
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          Good job !!!
                          • apppostol
                            • Nov 2020
                            • 4
                            • Russia
                            Guys, hello everyone! The situation happened exactly as described! Just after rebuilding the laptop, the symptoms became like the author's. I flashed bios from the forum thread and it all worked. Thanks for the info!
                            Парни, всем привет! Случилась ситуация точно как описано! Просто после пересбора ноутбука, симптомы стали как у автора. Прошил bios из ветки форума и все заработало. Спасибо за информацию!
