Antec Smart Power SL-400 5vsb mod using VIPer 22A
  • everell
    • Jan 2009
    • 1514
    Here is a step by step instruction for the Antec Smart Power SL-400.....eliminating the two transistor 5vsb circuit and installing a VIPer 22A pwm chip. The SL series is a current forward design rather than the less efficient half bridge. This modification can be done without removing either of the heat sinks. Pictures show the end result. Also a schematic of the original two transistor circuit and a schematic of the modified circuit using the VIPer 22A.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • everell
    • Jan 2009
    • 1514
    Re: Antec Smart Power SL-400 5vsb mod using VIPer 22A
    First step, build the add on mod board using commonly available perf board. Radio Shack sells this in 4 inch by 6 inch sheets. The schematic is shown using different colored wires to make assembly much easier. Pictures show top side of the board and bottom side of the board. There are only 5 parts used, a VIPer 22A chip, a 9.1K quarter watt resistor, a 1N4935 (or equavilent) high speed switching diode, a 4.7 uF/50 volt electrolytic capacitor, and a 10 nF film capacitor (usually marked 103).
    • everell
      • Jan 2009
      • 1514
      Next step is to remove jumper J2. One side of this jumper goes to the collector of the 5vsb switching transistor. The other side of the jumper will be used for attaching the red wire which goes to the drain of the VIPer 22A pwm chip. Removing the J2 jumper removes the switching transistor from the new circuit so that you don't have to unsolder it and remove it from the heat sink.
      • everell
        • Jan 2009
        • 1514
        Next remove Resistor R19. This is the startup resistor which provides the startup voltage to the two transistor circuit. Removing this resistor assures that no accidental startup problems occur.
        • everell
          • Jan 2009
          • 1514
          Next remove Coil L2. One side of this coil location will be used to provide the Vdd power to the VIPer 22A chip. The yellow wire will be be attached here a few steps from now.
          • everell
            • Jan 2009
            • 1514
            Now remove transistor Q5. The emitter of Q5 is grounded, so this ground location will be used to attach the green ground wire to the VIPer 22A mod board.
            • everell
              • Jan 2009
              • 1514
              Next remove Resistors R22 and R23. This will remove the optocoupler from the old two transistor circuit and give you the holes for attaching the blue and brown wires to the VIPer 22A mod board.
              • everell
                • Jan 2009
                • 1514
                Now it is time to work on the bottom of the power supply pc board. Attach the red wire to the hole formerly occupied by jumper J2 and as shown in the picture.
                • everell
                  • Jan 2009
                  • 1514
                  Next attach the yellow wire using one of the holes formerly occupied by coil L2 as shown in the picture.
                  • everell
                    • Jan 2009
                    • 1514
                    Next attach the green (ground) wire to the hole used by transistor Q5 emitter as shown in picture.
                    • everell
                      • Jan 2009
                      • 1514
                      Finally, attach the brown and blue wires in holes formerly occupied by Resistors R22 And R23 as shown in picture. Also, you will need to make one circuit trace cut as shown in the picture. This will prevent voltages from going back into the two transistor circuit.
                      • everell
                        • Jan 2009
                        • 1514
                        Check your work carefully to be sure you have no solder bridges. A small brush and alcohol can be used to clean the area you have been working on. Pictures show the 5 wires going from the VIPer 22A mod board to the main pc board and how I mounted the mod board to one of the heat sinks. You are now ready for smoke test!
                        • mockingbird
                          • Dec 2008
                          • 5484
                          I'm glad you reported back with the ultimate success with the Viper 22A on the Antec after you indicated erratic results in a previous thread. I want to carry out this mod, is the SL400 similar enough to the SP450 so that your instructions will work for this model too?
                          • LDSisHere
                            • May 2012
                            • 727
                            • U.S.A.
                            This is my interpretation of Everell's design. I have not etched it yet but I hope to do so before the end of the week.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              You're gonna etch it with the laser printer/acid/copper method?
                              • LDSisHere
                                • May 2012
                                • 727
                                • U.S.A.
                                Yes, that is the method I normally use.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Would you be open to selling me an SMD version? I just bought bulk stock of pick and place excess for pennies on the dollar, I don't know yet what size they are, but I'm betting I can put them to good use in this project.
                                  • everell
                                    • Jan 2009
                                    • 1514
                                    Here is a picture of the Antec SL-400 (front) and SP-350 (back). This shows the difference in the pc boards of the Smart Power SL series and the SP series. Both are sporting the VIPer 22A 5vsb modification. Now if we can get c_hegge to add a short instruction on how to modify the fans to operate correctly................
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      Ok, so I should look at the SP350 mod thread...
                                      BTW, he already has described his mod:
                                      Originally posted by c_hegge
                                      It's different for every fan controller, but I usually find out by temporarily soldering a Trimmer Pot in. Tweak it until you find a good idle speed, and once you're happy with it, remove it and measure the resistance, and find a resistor which is approximately what you had the pot set to, although be careful not to move the knob when you're removing the pot. I have one on a plug which I use for testing, so I can just unplug it when I'm done testing, and then unsolder the plug from the PCB. Since my plug is on wires, which I can have away from the PSU, it also saves having my hands too close to live components.
                                      EDIT: FWIW, It's about 2.4K for Antec Smartpowers, but In another PSU (similar to https://www.badcaps.net/forum/showpo...&postcount=103), it was about 6K.
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        What would be the result of using a 10k resistor instead of the 9.1K? I already have 10k but I would have to order 9.1K. No major deal, just not convenient.
                                        Thanks,
                                        Lloyd
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 02:30 PM
                                          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                          HP ProBook 430 G6 + Fitbit Versa Smart Fitness Watch Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Fitbit Versa Smart Fitness Watch Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Fitbit Versa Smart Fitness Watch boardview and 430 G6 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 12:00 PM
