help for this laptop Dell E5270 (LA-C621P)
  • razadom
    • Apr 2015
    • 105
    • Madagascar
    Hi all
    need help for this laptop Dell E5270 (LA-C621P) with Vpro CPU. I've got dump and flash
    it with but no success. The problem is the laptop go on just for few seconds no screen and then shut off. Probably bios.I attach the dump bios.
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: help for this laptop Dell E5270 (LA-C621P)
    try this and confirm if its working
    • razadom
      • Apr 2015
      • 105
      • Madagascar
      Thanks I will try this
      • estabilito
        • Aug 2020
        • 55
        • poland
        I have similar problem, laptop won't restar bios 3 times, just restart 1 time and go on for a while(more than few seconds) and then go off. Power button working and causing similar situation like after 1 bios restart.
        • peste
          • Dec 2016
          • 13258
          • ROMANIA
          post the original bios
          • estabilito
            • Aug 2020
            • 55
            • poland
            This is the orginal bios.
            • peste
              • Dec 2016
              • 13258
              • ROMANIA
              try...
              • estabilito
                • Aug 2020
                • 55
                • poland
                same problem on this bios. I dont have voltage on one coil PL604(+VCC_GT)
                • peste
                  • Dec 2016
                  • 13258
                  • ROMANIA
                  check that the route is not short.
                  • estabilito
                    • Aug 2020
                    • 55
                    • poland
                    Looks not shorted, similar resistanse as +VCC_CORE coil(PL603) - 17-20 Ohms
                    • gkkaru
                      • Jul 2013
                      • 6
                      • colombo
                      Thank you, this bios working for me
                      • saurav
                        • Jul 2017
                        • 15
                        • India
                        thanks.. worked for me.
                        • arslansharif
                          • Oct 2016
                          • 44
                          • pakistan
                          system number
                          6SW2TC2-6FF1
                          bios password
                          plz send the code
                          thanks in advance
                          • Gerry68
                            • Jul 2015
                            • 10
                            • germany
                            arslansharif
                            MasterPassword:
                            cNiGrbHNBimt4eEb
                            or
                            r0rE6N02d802qUr[
                            • amotechFIX
                              • Dec 2021
                              • 4
                              • Kenya
                              That helped thanks
                              • rachidell
                                • Aug 2016
                                • 137
                                • algeria
                                dell E5270 (LA-C621P)
                                ​slow to boot its take 40 second to boot
                                can help me
                                • peste
                                  • Dec 2016
                                  • 13258
                                  • ROMANIA
                                  can help me
                                  post the Service Tag..
                                  • rachidell
                                    • Aug 2016
                                    • 137
                                    • algeria
                                    service tag 7585s72
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      service tag 7585s72
                                      here dmi added and clean me
                                      • rachidell
                                        • Aug 2016
                                        • 137
                                        • algeria
                                        thank you
                                        • mikey5791
                                          Dell laptop model PP24L won't start from ac adapter
                                          by mikey5791
                                          Dear all,
                                          Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                                          But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                                          03-24-2023, 09:06 PM
                                        • Mots06
                                          Old Dell E5400 Laptop ( Purchased in the year 2008)
                                          by Mots06
                                          Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                                          07-19-2025, 01:56 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Calidebear
                                          Dell 3537 laptop doesn't boot without embedded display.
                                          by Calidebear
                                          I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                                          So checked the schematics to bypass this issue.
                                          Found something but I don't know how to read this schematics.
                                          Dell 3537 mobo 9982p rev 3
                                          Schematics attached,...
                                          03-29-2025, 11:37 AM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
