320 Touch-15IKB(81BH) 320-17IKB(81BJ) 520-15IKB(81BF) 320-15IKB(81BG 81BT) V320-17IKB
    • 21685
    Bios Ver. 6JCN32WW for the following models/model types:
    320 Touch-15IKB (Type 81BH), 320-17IKB (Type 81BJ), 520-15IKB (Type 81BF), 320-15IKB (Type 81BG, Type 81BT), V320-17IKB (Type 81CN)
    Make sure you check the Model Type.
    There`s an older thread with different Model Types - https://www.badcaps.net/forum/showthread.php?t=72785
  • riconl
    • Aug 2012
    • 2
    • Netherlands
    Re: 320 Touch-15IKB(81BH) 320-17IKB(81BJ) 520-15IKB(81BF) 320-15IKB(81BG 81BT) V320-1
    What do i do with the EC file? I have found a 25B62CSIG chip on the mainboard and flashed the bios.bin in it but the laptop still does not start.
    • peste
      • Dec 2016
      • 13436
      • ROMANIA
      the EC bios is for the I/O chip ... write the chip back
      25b64csig, with the original content ... I hope you made a copy before writing it ...
      • riconl
        • Aug 2012
        • 2
        • Netherlands
        Aha i have no equipment for writing the EC chip.
        • maxgarabedian
          • Sep 2021
          • 1
          • France
          Thanks a lot, i fixed my V320-17IKB with your BIOS file
          • Yumekonoi_
            • Oct 2023
            • 12
            • Italy
            Hi! I think i have a Lenovo 320-17IKB. There is a sticker but ther is no information about product or serial number on it..
            The laptop powers on for 3 seconds where the screen seems to go on, cpu fan is going and power led is on but for no reason it powers off.
            After disconnect all of the components that may be halting the power on, i think is a bios related problem.
            Is the first time that i try to programm a bios, i just bought a CH341A usb programmer BUT i think i MAY be wrong about the bios chip.
            Can someone tell me what the chip is? I think is the WinBond 25Q34JVSIQ but i'm wrong?
            The modo is a DG421 DG521 DG721 NM-B242 Rev.:1.0 2017-01-25 with vendor:PALWONN.
            Thank you so much!
            (i posted on old thread but i don't know how to delete it, i'm sorryy)
            • hoaca388
              Badcaps
              • Jan 2022
              • 12272
              Thank you so much!
              You look for any chip with the number 64 on the back. Ex: q25w64..
              • Yumekonoi_
                • Oct 2023
                • 12
                • Italy
                On the back there is nothing. On the top there is the chip that I mentioned before. I attach some photos. Thank you so much for the help!
                The third photo is the chip that I think is the BIOS.
                • Yumekonoi_
                  • Oct 2023
                  • 12
                  • Italy
                  Sorry, here there are the photos.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12272
                    There it is
                    • Yumekonoi_
                      • Oct 2023
                      • 12
                      • Italy
                      There it is
                      Thank you so much!
                      At first I was certain that it was right but then I saw it was near the GPU and i thought that i find the wrong chip 😭
                      Tomorrow that comes the programmer, what are the steps that I need to follow?
                      Read, save the readed config, and then? Is my first time doing it, I readed a guide online but if the bios file is broken how do I repair it? 🥺
                        • 21685
                        Thank you so much!
                        At first I was certain that it was right but then I saw it was near the GPU and i thought that i find the wrong chip ��
                        Read, save the readed config, and then? Is my first time doing it, I readed a guide online but if the bios file is broken how do I repair it? ��
                        It is essential that you make a good backup first before erasing the chip.When you have made a backup post it here,don`t erase the chip.
                        BIOS guides, methods, resources and tools
                        https://www.badcaps.net/forum/showthread.php?t=103526
                        1. How to dump and flash
                        https://www.badcaps.net/forum/showpo...40&postcount=2
                        1.1.1.6. CH341A
                        • Yumekonoi_
                          • Oct 2023
                          • 12
                          • Italy
                          1.1.1.6. CH341A
                          Tomorrow i will post here the backup.
                          Another question: to know at what voltage the chip is, i need to find it in the datasheet? I bought a 3.3/5v programmer, i saw after the purchase that i could buy it with a 1.8v adapter too. I need it or i'm okay with what i got?
                          When a bios is broken, is common that it losts the DMI (?) informations or they likely stay there?
                            • 21685
                            The chip is 3.3V .If you make a good backup the DMI info could still be readable,then its easy for one of our members to transfer it to a new bios for you.There could be some corruption in the backup,enough to make reading the DMI impossible.Reading a bios chip with a clip is notoriously unreliable,so make 2,3 or more backups and compare them.
                            • Yumekonoi_
                              • Oct 2023
                              • 12
                              • Italy
                              I know but because i'm new in all of it i did not want to spend a lot, if this become more and more frequent, i'll buy some more quality stuff.
                              I'll listen to you and make more backups.
                              To do all the thngs, the pc need to be connected to the power right? Battery connected and ext power?
                              I'm so sorry for all this questions but i want to make sure that i do all the procedures right
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12272
                                No power. AC , main battery, CMOS.
                                • Yumekonoi_
                                  • Oct 2023
                                  • 12
                                  • Italy
                                  Okay, with power i mean just ac plugged but no on because eather way it turns off by itself.
                                  It arrived this morning and i'll do the backup when i have a little bit of time
                                  • Yumekonoi_
                                    • Oct 2023
                                    • 12
                                    • Italy
                                    I'm currently reading the BIOS but idk what i'm doing wrong... the reading is all FFF's...
                                    I selected both W25Q64JV and BV but nothing.
                                    The usb stick have only the "Power" led active but no other one led is working, like "run".
                                    I installed the driver from the folder of "AsProgrammer". What i'm doing wrong? T-T
                                    Edit: tryed installing NeoProgrammer and says "IC not responding" even if i am connected to it.
                                    They gave me a faulty programmer?
                                    • Yumekonoi_
                                      • Oct 2023
                                      • 12
                                      • Italy
                                      Hi. I managed to have the bios files (it was the programmer faulty).
                                      I used both AsProgrammer and NeoProgrammer and saved in two different folder. Visually seamed to be different so I saved both.
                                      Thank you so much.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12272
                                        Thank you so much.
                                        Serial number ? this's forums' ruler
                                          Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 09:10 PM
                                          Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        • electronx
                                          Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                                          by electronx
                                          Hi everyone,
                                          I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                                          1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                                          According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                                          If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                                          06-26-2025, 03:27 AM
