Compaq missing driver
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    First a few specs...Its a Compaq Presario SR1720NX, product number EL435AA, Asus A8AE-LE mobo, 3500+ Simpron, 160Gig HD, ATI RADEON XPRESS 200 Graphics, some sort of card reader.
    It had a hundred gigs of downloaded games on it so I ran a system restore from the backup partition to start out fresh. Didn't work! The restore picked up most everything on the hard drive and put it in the new copy of Xp home. It still had a hundred gigs of junk on it. I figured I'd delete the windows partition using my Dell Xp Home disc. This did work but I deleted the wrong partition! WTF! Next I deleted all the partitions and reinstalled xp from my Dell disc and then used the COA on the Compaq case to activate windows. Now I downloaded all the need drivers from Compaq. I only have one yellow question mark. Its on something called a SM BUS CONTROLLER. I don't even know what the hell this thing is...I've tried some more drivers from compaq as well as a few work arounds I found online. Nothing seems to fix this issue. Somebody here knows what I need to do to fix this. I want to give it to my wife for mothers day. Its not new but its better than the old P3 DELL she is on now.
    Mark Twain
    John Paul Jones
    Rod Serling
  • NxB
    • Feb 2009
    • 1595
    Re: Compaq missing driver
    Ati smbus driver.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      OK Thanks! I downloaded the original version of the driver for the video. I'll go back and get the newest one and see if that fixes it.
      Mark Twain
      John Paul Jones
      Rod Serling
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        No luck yet...But I do like this PC! Its mhz's says its slower than my Dell...Yeah Right! This Compaq is smoking. If it were a Race engine I'd say it had alot of torque. Its been along time since I've praticed the black arts of AMD. Now I can see that if AMD wanted to compete with the likes of Intel and others, they did had to have chips that were at least in the ball game.
        Now that I'm not so tired and burned out from a long road trip I'll do a more detailed search for this ati sm bus controller thing.... Do you all think that this ati smbus driver would be on any of the driver cd's that I have for other ATI RADION products???? Is this smbus something that is a real part on my mobo or is it something that exists in software for some other part???
        Mark Twain
        John Paul Jones
        Rod Serling
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Far Out! Its fixed! Thanks NxB! Now I have to dump some of these ATI drivers and ATI BS software I've installed. The thing it needed was and ATI South Bridge driver thing of some sort. Is there a package of mobo drivers that I need for this PC? The driver that fixed this Compaq came from Dell and is numbered R134873. This thing is going to make it to her desk by mothers day now. Next I'm going to look into is this card reader thing. It may be unable to read an SD cards as big as the one in my camera. If this is true I'm going to uninstall the removable drives it creates and disconnect it.
          Mark Twain
          John Paul Jones
          Rod Serling
          • NxB
            • Feb 2009
            • 1595
            The smbus driver is separate from the video driver sometimes. Just don't install all the extras. If it comes with the video package smbus is listed and has a check mark just like the other stuff: wow trial, etc.
            The ati drivers are probably all that you need.
            • seanc
              • Nov 2008
              • 1319
              Just unplugging the card reader will make the extra drives go away, but if it's showing the extra drives, it should be working.
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                The card reader does work so I left it in. The video is now PCIe on a 128 meg ATI card. It works good. I did find it original recovery disk kit on the Compaq site. This isn't the restore disk that may have came with it. In fact I don't think it came with a restore disk at all. The restore was done from partition D. I killed this partition. I think this kit does all the partitioning and restores the hard drive to the way it came from Compaq and installs the OS...ect. Here is the number of this kit. "Xp home sp2 61nahered1 recovery kit" If anyone knows anything about this kit and the cost please let me know.
                Mark Twain
                John Paul Jones
                Rod Serling
                • seanc
                  • Nov 2008
                  • 1319
                  You don't need the recovery discs.
                  As long as you've got it up and running with the proper COA on the Compaq, it's fine, be done with it.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    AMD gave these processors model numbers like "3500+" and such because they were said to be comparable to a 3.5ghz P4 of the time, so it should be quite a bit faster than your 4550
                      HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:44 PM
                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                      HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                      This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                      09-12-2024, 03:36 PM
                      HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:30 PM
                      HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
