Yeah, I downloaded those registry tweaks a long time ago.
They didn't seem to make any difference for H.264 acceleration in Youtube or in VLC... so as far as I'm concerned, they haven't been very useful for any of my intended purposes.
Nah, these are slow cards already, I don't see why I should downclock them.
Also, there's no difference in specs for these low-profile cards between the ATI "XT" models and Dell OEM "Pro" models - both run with 650 MHz core and 500 MHz mem. On the other hand, the Pro AGP cards do run with slower clocks... or at least my VisionTek one does (525 MHz core and 390 MHz mem.)
Not that any of that matters, though. With only 64-bit memory, these cards are pretty slow for games, regardless of which variant you get.
They do well under Colin McRae Rally 3 / 04 / 2005, though, if anyone cares about some older rally games to try.
Did that at first, but wanted to reduce / reuse / recycle more
Of course, there was a reason why they were so cheap: DMS-59 output connector that requires a breakout cable for either D-sub or DVI. Most of the time, the DMS-59 breakout cable is not included and often costs almost as much as the card itself.
But I found another sub-$12-total auction that included 3x DMS-59 to dual D-sub cables and… more of these low-end OEM low-profile cards in the package
And from what I observed, the stock fan on the HD6670 heatsink did not run faster than the stock fan on the HD2400 heatsink (both being 50 mm fans), nor did the BIOS make it go faster under load (it ran at 13% PWM under full load and mostly off when the GPU was idle.) Kind of amazing what few mm of extra aluminum on the base thickness can do for the temperatures. Of course, I’m sure the extra cooling fins (approx. 2x more) helped too. Just as a comparison, here you can see the thickness of the stock HD2400 cooler (along with stock pink “bubble gum” thermal compound.)
The card ran nice and cool. With the same room temperatures as before, the GPU core hardly went over 45-46°C, and memIO area didn't go above 52°C. Even without my custom MSI Afterburner fan curves, the GPU temperatures didn't go more than 1-2 degrees up. The only downside is that the fans are much louder now – I can actually hear them. Before? – No.
However, the higher pixel and shader count of the 7600 GS is what makes it perform slightly better. As for the core clock: the 7300 GT is only 50 MHz slower than the 7600 GS. On that note, since this BFG GeForce 7300 GT uses the same exact PCB as my PNY GeForce 7600 GS card, I had no problems overclocking the core to 7600 GS speeds (400 MHz.) With a better cooler, it might even do 7600 GT core speeds (540 MHz.) From my short experiments with OC on this card, however, performance hardly improved at all when I bumped the GPU core to 7600 GS levels. And I'm not sure the RAM will take much OC either, as it already runs rather warm. Thus, the gains from OCing this card didn't seem to matter much. Nevertheless, the 7300 GT is still a very decent AGP card to have around. Should play early and most mid-2000's games at medium-high settings with decent FPS. Probably best matched with a Windows XP machine running on a mid-high-end Athlon XP or Pentium 4. I tested mine on a socket 939 PC with an Athlon 64 3200+ OCed to 2.5 GHz, and the CPU was almost never the bottleneck.
Its “other half” has been married to another video card for many years now (
before the seller shipped the item, he said that while testing the item before shipping out, there was some noise from the fan and that he included a second fan in the package.
i finally had an eureka moment. i decided to use cable ties and to use the stator frame of the original fan as an anchor point to secure the cable ties onto. i had to run two cable ties in a "U" manner under the stator frame and then screwed the stator frame back onto the heatsink with the original screws to secure the cable ties onto the heatsink.
... yeah, I'll put whatever I have that is better than their crap. I don't have any low-profile PCs, so I frankly couldn't give a crap about low-profile stuff. Besides, if you are stuffing a 50W+ video card in a small shoebox PC, you're doing it wrong. Most small SFF/USFF PCs already run way too hot inside. They don't need more heat. So a mid-range low-profile video card is a silly idea anyways... unless it really has a properly designed heatsink that exhausts all of the heat outside of the case - and those usually don't come in anything less than a dual-slot and full-profile.
the video card turned out faulty when i tested it and i had to file for a refund.
- that's with the fan barely turning too.
