Messed up start menu in Windows 10.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I was integrating drivers in a Windows 7 installation disc using Dism. It takes a while so I just wrote a batch script and let it run all night. Needless to say, it seems our kitten was using the PC last night.
    I suspect the start menu issue was from something she did. Now it looks like Windows 8 / 8.1 when we click the Windows square in the lower left hand corner. There's also a back button next to the Windows square in the lower left hand corner.
    My wife seems to be really upset about this. Does anyone know how I can get it back to the normal one? The one that looks like 7? The way it was yesterday before I went to bed?
    Any help is greatly appreciated. Thank you.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • chowder
    • Feb 2016
    • 44
    Re: Messed up start menu in Windows 10.
    I've seen this on a friend's machine, in the end we copied the settings from a new user account because we couldn't figure out a better way of doing it. Windows 10 sucks.
    Anyway:
    1.) Create a new local admin account on the system
    2.) Log off as you and on to the new account. The Start menu should look normal.
    3.) Copy the data in "C:\Users\(new username)\AppData\Local\TileDataLayer\" to "C:\Users\(usual username)\AppData\Local\TileDataLayer\"
    4.) Log off the account and back on to the original one, the Start menu should be fixed.
    5.) Remove the account.
    That's largely from memory, but I think that's how we did it. Hope it helps.
    • Spork Schivago
      • Mar 2012
      • 4734
      I figured it out. It was in what's called Tablet Mode. No idea how the kitten got it in Tablet Mode but unchecking it fixed the problem.
      • Spork Schivago
        • Mar 2012
        • 4734
        Anyway:
        In case you run into the problem again, in the lower right hand corner, by the date / time, there's an icon that shows messages. Stuff like Updates were installed, restart now, or There's more than 3 programs running at startup. Disable some to make your PC run faster, etc.
        If you click that, a window pops out from the side. At the bottom, there's a bunch of options. One says Tablet Mode. Click that to switch between the different modes.
        • japlytic
          • Oct 2005
          • 2086
          After a video driver upgrade (through Windows Update) on a Dell Studio 1555 after upgrading to Windows 10 (from a fresh Windows 7 install from its recovery image), the Start Menu stopped working; so I tried deleting the display adaptors from Device Manager, restarted, and problem fixed.
          • Spork Schivago
            • Mar 2012
            • 4734
            Did you try restarting with the new drivers installed? I know with 10, there have been problems with the Start Menu crashing. Usually, a reboot fixes it. If not, usually a Windows update fixes it. I know we had this problem many times before the 10 Service Release came out. That seemed to fix it.
            • japlytic
              • Oct 2005
              • 2086
              After a required restart, the problem remained, and deleting the display adaptor device as mentioned with a restart fixed this problem.
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
              • reformatt
                Windows 11 Start menu/Taskbar hanging
                by reformatt
                Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
                First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
                04-23-2024, 10:16 PM
              • japlytic
                DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                by japlytic
                In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                Tried (only with keyboard/mouse connected):
                • BIOS + database update
                • Using latest Windows 11 image built with official image creation tool
                • Previous setup version for Windows 11 installer
                • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                06-19-2025, 04:59 PM
                Acer Aspire Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) Notebook 7 Specification for Upgrade or Repair
                This specification for the Acer Aspire Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) boardview and Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD...
                09-07-2024, 01:00 AM
                Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                09-07-2024, 12:40 AM
