Weller PyroPen
  • gastorgrab
    • May 2007
    • 320
    Weller PyroPen
    Is there any problems with using something like this;
    This is what i use regularly at work and i have a good 'feel' for the tool. I'm wondering if there could be a problem with static charges between myself and the board i'm working on.
    I've heard this tool compared to a 80watt iron.
    Good enough, or don't do it?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Weller PyroPen
    ground the board to yourself, and you should be ok as far as ESD. NEVER use those 'cold heat' type irons on a motherboard though, you'll fry the board. I have a butane soldering iron I've used for field repairs on motherboards, never had any problems with it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • gastorgrab
      • May 2007
      • 320
      Re: Weller PyroPen
      • gastorgrab
        • May 2007
        • 320
        Re: Weller PyroPen
        For futue reference, i measured 820 degrees F (438 C) on the low setting, and 880 degrees F (471 C) with the valve wide open.
        This was read with a 24 guage 'K' type thermocouple in direct contact with the tip.
