dimension gets an upgrade
  • pentium
    • Mar 2006
    • 2778
    Today I got a large load of cpu's in and one of them was one of these running at 1.2 Ghz.
    The first thing I look at for upgrading is my Dell dimension 4100. It's already got a 1ghz cpu installed but it's not of the Tualatin series, it's a coppermine.
    I have heard that some boards can't support Tualatin cpu's and the regulators or the CPU burn out because of this. Am I safe to install this new cpu or should I add this to my items for sale?
    Find Nedry!
    Check the Vending machines!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: dimension gets an upgrade
    you'll actually be downgrading. a 1000/133 P3 coppermine is faster than a 1200/100 cellie. The loss of FSB speed will harm you more even with the 200MHz core gain.
    http://powerleap.com/PL-NeoT.jsp
    That adapter will allow you to run a tualatin in a board not designed for one. All that's required is the board supports coppermines (which it obviously does), and the chipset supports the higher multiplier.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • pentium
      • Mar 2006
      • 2778
      Well in that case I will stay coppermine.
      If I have to shell out to get a performance decrease then I'm wasting my money.
      Find Nedry!
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Now if you got that adapter and stuck a 1.26 or a 1.4GHz Tualatin-S in it, you would gain. They have bigger caches and run really cool. It all depends on what you plan to use the server for.
        This site is currently hosted on a dual P3 Tualatin 1.4GHz on a Supermicro P3TDDE motherboard with 2gb ECC RAM, and it's quicker than the old server, which was a Celeron 2.4GHz 1gb RAM. Granted, this server is only temporary, while I design and build some new stuff, it has no problems keeping up with things.
        Team : 49813
        Join in!!
        Team Stats
        • pentium
          • Mar 2006
          • 2778
          Yeah but I don't have a cpu that fast in socket 370 form.
          If I did have one then It would sound like a good upgrade.
          Find Nedry!
          • ugamazing
            Procedural question about BGA rework and removal of CPUs
            by ugamazing
            I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
            I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
            I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
            07-12-2022, 03:11 PM
          • Nebukadnerzar_V
            Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
            by Nebukadnerzar_V
            Hi guys!
            I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
            It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
            I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
            Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
            Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
            I have attached the Dump of my machine.
            S/N: SRW2K4J
            Reg Model: DCTR...
            09-27-2024, 02:43 AM
            Dell Dimension 8200 Schematic
            LA-1221...
            10-04-2024, 07:48 AM
          • ducky29
            Working with Bga chips especially CPUS
            by ducky29
            Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
            Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
            Thanks in advance.
            09-23-2024, 03:56 PM
          • SwedishDiesel
            Dell Dimension PSU Compatibility - B110 PSU in 4550
            by SwedishDiesel
            Howdy folks,
            I've risen from the grave to ask more questions about old obsolete Dells.
            I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
            The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
            12-18-2022, 06:58 PM
