SAMSUNG CLP-325 printer
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    red light on and any function... any suggest?
    09-07-2024, 05:50 AM
  • Kaar3l
    Samsung QLED QE65Q7FNAT only standby light
    by Kaar3l
    TV: Samsung QLED QE65Q7FNAT
    PSU: BN4400940A
    MB: BN94-12832K
    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
    09-24-2024, 01:35 PM
  • marcinq
    Samsung UE60KS7000 No Standby Light
    by marcinq
    I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
    I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
    05-26-2025, 11:36 AM
  • DXseekerMO
    Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
    by DXseekerMO
    Hello everyone!
    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
    Symptoms:
    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
    2) TV does not appear to turn on
    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
    4) "Power on" terminal on Power Supply has 3.26v
    5) "A13V" terminals have 12.9v
    6) Stand-by test jumper on Power Supply has 12.9V
    7) Optical audio jack on Main Board illuminates
    8) With stand-by...
    06-09-2021, 12:19 AM
  • ChristianBr01
    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
    by ChristianBr01
    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
    04-23-2025, 01:48 AM
