It appears that after researching the different alternatives to getting an additional speed boost out of my new rig, I have once again acquired the overclocking bug. I'm therefore considering attempting a BSEL pad mod on my E3400 celery since essentially that is the only way I can overclock my rig since the OEM BIOS is nerf'd. If successful the CPU should be running around 3.4ghz (266x13, up from 2.6ghz) with a FSB of 1066. I'm thinking this should bring the performance of the CPU up to the equivalent of a mid range E7000 series or low end E8000 Core 2 Duo simply due to raw frequency increase.
I hear these CPU's are capable of hitting 4ghz on air... think such a moderate overclock would be doable using the stock cooler and Vid?
The other option would be to purchase a used CPU... but they are not exactly cheap... and pretty much anything less than a E6850 C2D would be a downgrade according to the benchmarks I have seen.
Thoughts?
Thoughts?
