recover a dead mobo
  • silver310
    • Jun 2012
    • israel
    recover a dead mobo
    hey everyone, new to this forum.
    So i have this old build i decided to fire up to use as an HTPC in the living room.
    the mobo is a GA-8N-SLI Quad Royal http://www.gigabyte.com/products/pro...px?pid=1957#ov
    after days of trying to get the pc to boot i finally got it, all thanks to a dry contact cleaner, spray that everywhere and it boots! haha.
    ran some HDD/mem tests and everything was working great exept one ram stick, so i just didn't use that one.
    then i updated the bios, main bios updated without a problem, so i chose to boot from beckup bios via Q-Flash so i can update that one too, and here is when the problem begins, after restarting the pc it just won't boot via beckup bios.
    turned on the pc and waited for 1 hour, no boot, no beep or visual on screen.
    i cleard/earesed CMOS by removing the batter (witch was dead i think, bios didn't save any setting whenever i turned off the psu) also via the 3 pins by changing the jumper from 2-3 to 1-2 pins.
    right now the mobo is turned on with nothing but the cpu in it, and still nothing, not even a beep.
    Also tried forcing bios recovery with some tricks i read online by holding the power button etc, didn't help.
    I'm a computer technician in a PC store so i know what i'm doing, what i don't know is if after clearing cmos does the mobo reset it self to boot from main bios? or does it stay on the beckup one, i read somewhere that i can enable/disable the bios chips by shorting out 2 pins, but every guide i read says something different, my bios chip is a SST49LF004B http://pdf1.alldatasheet.com/datashe...33-4C-NHE.html
    anyway any help would be great, that build was my first ever pc i got with my own money and build myself, so if i can revive it i would be super happy.
  • Loli Popu
    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 03:28 AM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
    by Vesko356
    08-11-2023, 03:27 AM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • tranquility
    Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
    by tranquility
    hallo,
    i have an asus X515KA-EJ058W here.
    just both leds white...he battery blinking without battery connected
    consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
    if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
    power on again is possible but again 400mA then and no picture.
    now the really strange
    i flashed bios (some version i found on the internet) and resoldered....sometimes...
    12-11-2024, 06:47 AM
