Hello.
I have been visiting the forums here for some time now. Since I know that there are people with knowledge about electronics here, I decided to ask you guys about the problem with my Samsung HDD. It's the model SP1614N, a 160GB, 7200 rpm PATA disk with 8MB cache and a nice, silent Nidec spindle motor.
I go to university abroad and move the hdd back and forth a number of times each year. It was working fine before. The problems began when I last came home and put in into my computer to do a fresh install of XP. Anyway, the symptoms are:
1. During POST, I get the "primary/secondary master/slave drive fails" error, depending on how the hdd is connected.
2. After POST, I get the "Disk boot failure, insert system disk..." error.
3. When connected to either channel with another hdd, transfer mode drops to PIO.
4. SMART doesn't work but this was actually going on for a long time now but I didn't have any related hardware problems before.
The strange thing is, I've installed XP on an old Maxtor hdd and can still use the Samsung as a back-up disk. I encountered absolutely no errors of any kind during all this time using it this way.
I've done a full surface scan with Samsung's HUTIL. No badblocks were found. I've also done a low-level format to no avail.
So the only thing wrong with it, it seems to me, is the PCB board. Now, I could go a buy a nice new SATA hdd but I'm stuck with my old computer for some months and the mainboard doesn't support SATA (KT266A). I suppose it would be okay if I could obtain a working PCB but I don't think I'd have much luck with that.
Any ideas?
Sorry for the long post.
Any ideas?
