Being all bummed out about shelling $40 for new capacitors I discovered that my iron was too cold. I then had to spend a good hour and a half in a cold garage slaving over a dim light and a hot soldering iron. In a split moment however I noticed on one hole a problem...bart of te foil tube was ripped out!
I tried to ignore the obvious and continued on. At dinnertime tonight i completed reassembly of the computer. I plugged it in, switched on the APC and took a deep breath as i pushed the button.
First, the speakers popped.
Then the drives began to spin up.
And finally, the sound of success.....
BEEP!!
Even with a damaged foil tube the board is running fine and is incredibly stable. Thanks to all who helped me on this project.
BEEP!!
