Re: Dell used to be really good quality....
Because there just there to link two circuits together. It could be a jumper wire instead.
Some of the caps will be Low ESR, some will be general purpose. The best thing is to traw a diagram of all the wiring, then desolder the wiring to get the PCB free, and then mark, measure, and identify all the caps.
List them here along with the series and I will tell you what to get.
As for my preferences, I like UCC the best.
I think I can get the right replacements. But Low-ESR, High Ripple Current? Any series you like in particular? Almost anything has to be better than this crap.
I think I'm going to do a full recap...
Are coupling capacitors electrolytic? And what is the reason behind not replacing them?
Thanks for all of the help.Leave a comment:
1) Yea looks like you have an older GX150. The GX150s I work on all have the Pentium 1.13 chips and they have two 6.2 2200 HM/KZG/MBZ on the VRM which sticks up from the board, and 5 more HM/KZG/MBZ on the board.
2) That Teapo primary does look bulged. I would replace every last capacitor in the PSU, except for the coupling capacitors (Though I don't know how to identify a coupling capacitor).
If you need help, I can point you in the right direction regarding which replacements to get.Leave a comment:
Getting back to the Dell thing. I just decided to pop open the GX150's power supply. Mockingbird, you were almost dead on. It had two Teapos on the primary/PFC circuit. There's no active PFC so there's a 115/230V switch on the back, and hence the two caps. Could be making that up...believe I'm right.
Anyway, two Teapos and the rest are G-Luxon. I'm starting to regret making this thread now. Enterprise workstations with G-Luxon? Yeah aaaight.
There are in fact two swollen G-Luxons in the PSU which makes me think that perhaps the computer is running like shit because of some faulty ripple suppression or something. The others don't look all that hot either. They aren't swollen but I doubt they've stood up to 8 years of wear and tear too well.
So if a PSU has bad caps, can it harm your motherboard etc.? What I am trying to say is: If I replace the caps for a new bucks, would it be pointless "now that the damage has been done"? Or would it be an okay idea. I don't use it much anymore, but it was actually quite zippy (for an 833MHz computer) up until about 2 years ago.
The KZGs the GX150 is being accused of seems to be either a false accusation or I just have a lucky model. I have around 3 OSCONs, and around 4-5 UCC LXYs. So no KZGs in sight.
Anyway, here are some pictures. (Still working on my photography, don't hate!) Since all the Chemi-cons were conveniently placed that I could not fit the camera lense to snap a photo of the printing, you just get the date codes etc.However, trust me when I say they were LXYs.
Za pictures...
UCC LXY:
Teapos (these look swollen to you guys?):
G-Luxon:
Swollen:
Outside of those situations the extra cores just don't do much so there is really no point in having them in a PC. [PC = PERSONAL Computer.]
I must disagree strongly with you here.Leave a comment:
Oh really....well seeing that I don't use this computer much, maybe I'll give it a look. Eww Ltec and Teapo? Teapo is usually alright. Not the best, but Ltecs. Shame shame.Leave a comment:
With the exception of mobile versions, some Xeons, and those branded 'Extreme' all the 45nm & 65nm '2-Core' 'Core architecture' CPUs are 65 watts TDP.
[The 45nm 2-core is no different than the 65nm 2-core in that aspect.]
As a point of reference:
The fastest P4 [Netburst] with less TDP is a 2.6/512/400 or a 2.53/512/533.
- And unlike the 'core' CPU's, those P4's have no form of 'Speed-Step' so the 'core' CPUs actual power use [and heat dissipation] is much less than their TDP implies when comparing then to a P4 Netburst.
Short of bad cooling or a poorly designed motherboard I can't see any way for a Core based 2-core to be considered as one that 'runs hot'.
Now, some of the 4-cores run hotter.
- But AFAIK there is no -practical- use for a 4-core outside of an Enterprise Class server or a 'serous' workstation. [And I mean 'Workstation' by the industry definition.]
.Last edited by PCBONEZ; 03-23-2011, 01:08 PM.Leave a comment:
there's virtually no difference.. maybe 1-3°C .. it's not like they run 10+°C cooler or something lol
my 65nm Core 2 Quad Q6600 overclocked from 2.4 to 3.6 currently idles at 33°C with a 92mm fan at roughly 950rpm. (old cpu-z validation with lower multiplier)
and my old Core 2 Duo E4300 which was OCed from 1.8 to 3GHz wasn't really hot-running either.. (same cooler.. Arctic Freezer 7 Pro in the old revision (black fan blades & not i3/i5/i7 mounting compatible))Last edited by Scenic; 03-23-2011, 12:27 PM.Leave a comment:
I think Dell has gone downhill trying to keep production costs low so they can sell a 299$ computer. I also believe that alienware which is owned by dell now has gone downhill i have repaired two of the laptops in the last month and one about 2 years old had bad memory and the other had a bad motherboard. I love it when people buy the cheapest computer they can find then they complain that it is slow and after two years parts begin to fail.Leave a comment:
yeah, core 2s run cool. On my one, the temp. control never even turns the fan on for anything but heavy load stuff like gaming (and even then, it runs quite slow like 500RPM), although my case does have excellent ventilation.
EDIT: That's with an overclock from 3GHz to 3.6GHz, so it would probably run a bit cooler without the overclock.Leave a comment:
EDIT: That's with an overclock from 3GHz to 3.6GHz, so it would probably run a bit cooler without the overclock.Last edited by c_hegge; 03-23-2011, 04:14 AM.Leave a comment:
(or you're using crappy coolers lol)Leave a comment:
I don't think Dell is any worse than anyone else.
They sell MORE so you see them more often.
.Leave a comment:
The GX150 SFF with the Rubycons only (They're rare 1 out of ten of them let's say) are always fine. Mind you, there are only seven big caps total on the whole motherboard 7 x 6.2 2200uF MBZ/HM/KZG class. The HMs always fail and the KZGs are hit and miss.Leave a comment:
~ALL~ USFF & SFF boxes cook caps. - That's not a "Dell issue" either...Leave a comment:
This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:44 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:44 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:36 PM
This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:36 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:30 PM
- Loading...
