DSDT discussion
  • Agent24
    I see dead caps
    • Oct 2007
    • 5096
    • New Zealand
    DSDT discussion
    I installed the program and run the commands you stated. This is the result.
    I have pretty much no idea what all this is for...
    Code:
    agent24@INTEL3333:~$ iasl -d dsdt.dat
    Intel ACPI Component Architecture
    AML Disassembler version 20090521 [Jun 30 2009]
    Copyright (C) 2000 - 2009 Intel Corporation
    Supports ACPI Specification Revision 3.0a
    Loading Acpi table from file dsdt.dat
    Acpi table [DSDT] successfully installed and loaded
    Pass 1 parse of [DSDT]
    Pass 2 parse of [DSDT]
    Parsing Deferred Opcodes (Methods/Buffers/Packages/Regions)
    Parsing completed
    Disassembly completed, written to "dsdt.dsl"
    agent24@INTEL3333:~$ iasl -tc dsdt.dsl
    ASL Optimizing Compiler version 20090521 [Jun 30 2009]
    dsdt.dsl  124:   Method (_WAK, 1, NotSerialized)
    Warning 1080 -        ^ Reserved method must return a value (_WAK)
    dsdt.dsl 2632:           Field (ERAM, AnyAcc, Lock, Preserve)
    Error  4075 -                ^ Host Operation Region requires ByteAcc access
    dsdt.dsl 2870:           Field (ECRM, AnyAcc, Lock, Preserve)
    dsdt.dsl 3039:             Return (Local1)
    Error  4050 -                   ^ Method local variable is not initialized (Local1)
    ASL Input: dsdt.dsl - 4399 lines, 172253 bytes, 1882 keywords
    Compilation complete. 3 Errors, 1 Warnings, 0 Remarks, 783 Optimizations
    -David VanHorn
  • NxB
    • Feb 2009
    • 1595
    Re: DSDT discussion
    Its for "fixing" the ACPI table so it works properly in linux. Windows just works around ACPI bugs. Something didn't compile right, look at the documentation for iasl and see if the errors actually make a difference.
    • mockingbird
      • Dec 2008
      • 5488
      Re: DSDT discussion
      Can you upload the DSL file, so I can compare the fixes 67GTA did with what was there originally and then inform you of it. As well, can you tell me of a good free text editor like Kate for Windows that will show me line numbers? Wordpad isn't doing it.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5096
        • New Zealand
        Re: DSDT discussion
        There are many but I would use Notepad++
        I'll get that file uploaded soon
        -David VanHorn
        • Agent24
          I see dead caps
          • Oct 2007
          • 5096
          • New Zealand
          Re: DSDT discussion
          OK here's the file (inside zip archive so it could be uploaded)
          -David VanHorn
          • piernov
            Compaq SR1000 MSI MS-6577 ACPI fix
            by piernov
            Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
            ACPI fix!
            Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
            Bug
            Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
            At boot, you may be greeted by the following message:
            Code:
              [ 0.000000] ACPI Error: A valid RSDP was
            11-30-2021, 02:34 PM
          • angel35
            Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
            by angel35
            An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
            (like below picture)
            What can cause somethimes ok, somethimes not good ACPI state? Really strange
            If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
            Wong Bios IC? Power problem?
            Wrong status:
            Good status somethimes:
            07-27-2024, 04:04 PM
          • sylvain_92
            iMac 2009 A1312 2009 not booting - 3rd led not on
            by sylvain_92
            I am trying to repair my iMac A1312 late 2009 intel i5.
            First of all it was booting but no screen on internal lcd but working with external one,
            I tried:
            - another screen and led power board (booting no screen - same as before)
            - another mxm graphic card (not booting missing 3rd led)
            * screen and mxm gpu tested are 100% working on another A1312 iMac.
            I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
            The main...
            12-23-2022, 03:36 PM
          • tom.tom
            Two iMacs 2009 - black screen, backlight OK, GPU OK, four LEDs on - any ideas?
            by tom.tom
            I've recently got two 2009 iMacs (820-2733-A) with the video issue I have never come across before. The symptoms are as described briefly in the topic:
            • both boot with chime and load the OS (Live Linux from USB),
            • four LEDs are on,
            • the LCDs get the backlight, but no video data (black screen with just the backlight),
            • no video on the external monitor,
            • GPUs are 100% OK,
            • LCDs and LVDS cables are 100% OK.
            How do I know the listed components are ok - have working 2009 iMac C2D to exchange the components with.
            I suspect motherboards, but two iMacs with...
            07-15-2022, 08:41 AM
          • kotar
            Asus X452c ACPI error
            by kotar
            can someone help me ACPI bios error of Asus X452c ,backup bios is attached...
            11-19-2023, 11:10 PM
