intel ICH9R raid question
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    my intel dp35dp has the ICH9R raid chip in it.
    someone in another thread mentioned it was not fakeraid.
    is it fakeraid or is it hardware raid? reason I ask is since i am getting a hard drive for it soon, i want to know if it it is worth it to get 2 drives or not.
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: intel ICH9R raid question
    my research says fakeraid.
    anybody care to comment?
    sigpic
    • mockingbird
      • Dec 2008
      • 5484
      It is fakeraid. ICH raid will show up as seperate drives in Linux.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        what i thought. one hard drive it is.
        sigpic
        • mockingbird
          • Dec 2008
          • 5484
          Not to mention that without TLER/CCTL support, the drives you would have bought would be dropping out of the array like flies.
          • yyonline
            • Jul 2009
            • 692
            It's software raid...but it's still faster than a single drive. My main PC is P35 chipset and has 2x velociraptors running raid.
            • mockingbird
              • Dec 2008
              • 5484
              It's kind of hybrid. You can kind of make it transparent to the OS because it's done from the BIOS, so you don't need to mess with it in Windows, but it's not true hardware raid because it doesn't preform like true hardware raid.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                or essentially fakeraid.
                sigpic
                • mockingbird
                  • Dec 2008
                  • 5484
                  The first thing that comes to mind when you say fakeraid is software based raid. Because technically, there must be some hardware acceleration in ICH raid.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    fakeraid= sw raid with a bios-like firmware. it acts like hardware raid but the actual calculations are done by the cpu. like promise and highpoint controllers on older motherboards.
                    sigpic
                    • brethin
                      • Dec 2008
                      • 1907
                      There are software based raids, like what most OS's do at the kernel level does (this is what I would call fakeraid).
                      There are firmware/driver based raids, which are implemented correctly according to the raid standards (I would not call these fakeraid).
                      And there are hardware based raids.
                      ICH9R is a firmware/driver based raid.
                      The term fakeraid was used to identify software based raids form hardware based raids.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Originally posted by wikipedia
                        Operating system-based RAID doesn't always protect the boot process and is generally impractical on desktop versions of Windows (as described above). Hardware RAID controllers are expensive and proprietary. To fill this gap, cheap "RAID controllers" were introduced that do not contain a RAID controller chip, but simply a standard disk controller chip with special firmware and drivers. During early stage bootup the RAID is implemented by the firmware; when a protected-mode operating system kernel such as Linux or a modern version of Microsoft Windows is loaded the drivers take over.
                        These controllers are described by their manufacturers as RAID controllers, and it is rarely made clear to purchasers that the burden of RAID processing is borne by the host computer's central processing unit, not the RAID controller itself, thus introducing the aforementioned CPU overhead from which hardware controllers don't suffer. Firmware controllers often can only use certain types of hard drives in their RAID arrays (e.g. SATA for Intel Matrix RAID), as there is neither SCSI nor PATA support in modern Intel ICH southbridges; however, motherboard makers implement RAID controllers outside of the southbridge on some motherboards. Before their introduction, a "RAID controller" implied that the controller did the processing, and the new type has become known by some as "fake RAID" even though the RAID itself is implemented correctly. Adaptec calls them "HostRAID". Various Linux distributions will refuse to work with "fake RAID".[9].
                        i always heard it was the driver raid that was fake because it looks like hardware to noobs but in reality is not.
                        if i am doing raid, i want hardware raid. not crappy sw or driver raid.
                        sigpic
                        • brethin
                          • Dec 2008
                          • 1907
                          You are almost correct here.
                          1.) fakeraid = SW raid (at the kernel level)
                          2.) not fakeraid = bios/firmware based raid (yes it uses the CPU)
                          3.) not fakeraid = hardware based raid (same as #2 but has a dedicated CPU)
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            we posted at he same time. see my new post. "fakeraid" apparently has 2 different definitions.
                            sigpic
                            • mockingbird
                              • Dec 2008
                              • 5484
                              For a simple Raid 1 or Raid 0 array, bios-based raid is enough. Like I said, the more important thing is that you have the proper harddrive for raid.
                              For companies that want to do Raid 5, they should use controllers.
                              • brethin
                                • Dec 2008
                                • 1907
                                /Agree
                                And with the speed of todays CPU's you don't need a dedicated cpu controller for a good raid 0 or raid 1 array in a none server type application.
                                The harddrives are the more important part here that is for sure.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  well, I have a 2 port 3ware card in my fileserver. I know from experience how non-hw raid bogs performance. it's not like i have a c2d or a c2q in it... all it is a pdc.
                                  sigpic
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    The ICH9R will blow away that 2 port 3ware card in performance with a raid 0 or raid 1 array with a Pent Dual Core and 2 good drives.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      then which is faster? one drive or 2?
                                      will it play nice with linux? thats my only other concern.
                                      sigpic
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        Yes. Has great compatibility with Linux, provided you configure it correctly.
