Folder Is empty
  • zioricci
    • Jan 2023
    • 125
    • Italy
    Folder Is empty
    My Toshiba laptop stopped at the Toshiba logo when starting up, I flashed the bios and fixed it. Fortunately I had also backed up the data folder on an HP laptop with which in the meantime I reinstalled Windows 10 on the Toshiba hard drive using it as an external drive with which I am able to start the Toshiba after the problems solved.
    The real problem now is when I copy and paste the data folder from the HP back to the Toshiba hard drive, again using it as an external drive on the HP. In fact, when I put the disk back in the Toshiba, it tells me that The folder is empty but in the properties of the faith disk it is clear that the space is actually occupied by the right size of data. How to make this data visible
    Thanks!
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Folder Is empty
    Maybe not your case , but try this anyway : from control panel open "File explorer options" and check the box "Show hidden files and folders and drives " and next apply ..
    • zioricci
      • Jan 2023
      • 125
      • Italy
      Re: Folder Is empty
      I know this maneuver, already applied but without success. thx
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Re: Folder Is empty
        Okay .. I next suggest you run a powerful Antivirus , some types of viruses can lock files , and next you have to take the possibility of a going wrong transfer operation , due to a randomly malfunctioning device or a bad sectors growing in the related Hard disk ..
        • zioricci
          • Jan 2023
          • 125
          • Italy
          Re: Folder Is empty
          Chkdsk ?
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Re: Folder Is empty
            Why not ? .. Let me say also that the last attempt which I do not recommend but as the last resort , is to format the hard disk , and since you're customed to Easus is to use it as file recover .. Of course , that's not fully guaranteed ..
            • Radio Fox
              • Jan 2010
              • 281
              Re: Folder Is empty
              When you copied the Data folder from the HP to the Toshiba disk, did the files show up then, before you put the disk back into the laptop?
              I have had problems in the past when copying a folder with thousands of small files. I ended up having to copy them in batches, a few hundred at a time.
              ________________________________________________
              Invisible airwaves crackle with life
              Bright antennae bristle with the energy
              • zioricci
                • Jan 2023
                • 125
                • Italy
                Re: Folder Is empty
                I formatted many times
                • zioricci
                  • Jan 2023
                  • 125
                  • Italy
                  Re: Folder Is empty
                  chkdsk didn't fix it
                  • zioricci
                    • Jan 2023
                    • 125
                    • Italy
                    Re: Folder Is empty
                    yes, they were all present
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      Re: Folder Is empty
                      I use Active recovery for easy operations and spinrite for difficult ones .. Best luck anyway
                      • zioricci
                        • Jan 2023
                        • 125
                        • Italy
                        Re: Folder Is empty
                        For now I formatted once again and I'm trying to share between the two computers
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          Re: Folder Is empty
                          I'll keep following ...
                          • zioricci
                            • Jan 2023
                            • 125
                            • Italy
                            Re: Folder Is empty
                            the transfer is too slow, it even reaches 4Kb/s
                            • jiroy
                              • Jun 2016
                              • 2416
                              • Lebanon
                              Re: Folder Is empty
                              Pretty low ... Well , some Data rescue missions could take days ..Unfortunately
                              • zioricci
                                • Jan 2023
                                • 125
                                • Italy
                                Re: Folder Is empty
                                Now the speed has improved and this time I have left the hard disk in the Toshiba and so far the files are present
                                however I'm curious to move the disk to HP and see if they are visible there too
                                and another curiosity is to check if by returning the disk to the Toshiba, the files remained permanent
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  Re: Folder Is empty
                                  Copy the files to another disk once you recover them, then move shit around and see what happens.
                                  • jiroy
                                    • Jun 2016
                                    • 2416
                                    • Lebanon
                                    Re: Folder Is empty
                                    I'm still following this , frankly , because I dislike to bring bad news , but I strongly believe this device is failing ... To reach such very low speed , it's not good and , What's sure , it's not reliable anymore .
                                      09-06-2024, 05:27 AM
                                      09-06-2024, 05:59 AM
                                      09-06-2024, 05:33 AM
