Asus P5KPL-AM EPU power on-off issues
  • Justin1091
    • May 2018
    • 50
    • The Netherlands
    Hi guys,
    Two weeks ago I took this old motherboard from an old PC and installed it into another one. The board's been powered down for a couple of months when it was in the old PC.
    So, installed it in the 'new' pc case, put in a new 3.3v battery, powered it on and installed Windows and it was fine for a couple of days. Two days ago clicking shutdown in Windows makes the PC shut down but immediately powers it on again. Powering it on is also not possible with the button on the case. Shorting the power on pins on the motherboard also doesn't work.
    What does work is flipping the power switch on the PSU, then it turns on fine and everything is ok, except powering off of course. Voltages in the BIOS also look fine.
    I took the motherboard out of the case to check if there was something shorting underneath the motherboard in the case, but no difference.
    A different PSU shows the same symptoms.
    Bad capacitors on the motherboard *maybe*? Any suggestions what else to check? I looked at the motherboard and I couldn't see anything bad like bulging capacitors. I can take a look at them (brand, etc.) and report back here if that might help.
    Thanks!
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Asus P5KPL-AM EPU power on-off issues
    try clearing the cmos with the clear cmos jumper. sometimes after changing the cmos battery, the board will become glitched until the cmos is cleared.
    however, im most likely guessing it will still behave the same after that. in which case, it sounds like a shorted southbridge and/or super io chip caused by esd. u did take anti-static precautions, did u? only plug in the psu cable into the mains last after plugging everything else in and after u are done tinkering with the innards? also was there a thunderstorm recently? it might have been damaged by lightning.
    u can also try with the mains plug disconnected. hold down the power button for a few minutes, then plug in and try again. sometimes that method works for reviving a mobo that wont power on due to esd issues.
    • Justin1091
      • May 2018
      • 50
      • The Netherlands
      No, there weren't any storms last weeks. I confused another PC with this one about replacing the battery, I didn't replace this one's battery as it is still good. So, I only transported it in it's original bag and installed it in the new PC case.
      Anyway, did the main plug power button thing you said but didn't work. My guess is that this is it then. Too bad, it wasn't exactly new or fast but still a shame.
      Thanks for your help though.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        nope its not done yet. it could be that the previous psu was poorly built and damaged something on the mobo and it will no longer power on due to the damage already done regardless of the psu.
        so dont junk it just yet. perhaps someone with more experience than me can help. in the meantime, i recommend u post pictures of the mobo so other members can study the pictures to see if anything is off with the board.
        • CapLeaker
          Leaking Member
          • 8303
          unplug the computer, take the memory battery out for a while, then plug it in and press that power button without that battery being installed.
          Make sure that all plugs and socketed IC's are properly seated
          • Justin1091
            • May 2018
            • 50
            • The Netherlands
            I did these things guys, didn't work. A new motherboard has become available to me, so it's obsolete now. Won't throw the old one away yet though.
              ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
              This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 10:50 PM
              ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
              This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 11:05 AM
              ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
              This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
              This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
              This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 07:07 AM
