Panasonic FR Series in PSU?
  • jedwar10
    • Aug 2009
    • 43
    I've found a Panasonic FR series 16v 4700uF 12.5mm x 35mm cap and was wondering if it would be acceptable for use in a PSU that originally was filled with Teapo SC series. It's a Silverstone SST-ST65ZF. Going to be used in a server.
    Part # EEUFR1C472L
    Specs:
    3750 ripple @ 100kHz
    .012 impedance @ 100kHz
    10000 endurance hrs
    They are listed in the spec sheet as Low ESR (Same as FM Series)
    • 30932
    Re: Panasonic FR Series in PSU?
    yes.
    i use them in psu's all the time.
    • jedwar10
      • Aug 2009
      • 43
      Any suggestions for a 16v 2200uF 10mm cap also for PSU?
      I see badcaps offers the Rubycon PX series in that size but the ripple for PX is 1050 w/ impedence ?? and the teapo ripple is rated at 1780 w/ .032 impedence.
        • 30932
        2200uf 16v 10mm is available in panasonic FK series.
        • jedwar10
          • Aug 2009
          • 43
          Not to be a pest but the FK series are all surface mount as far as I can find.
          Do you possibly have a part number when you've ordered one before?
            • 30932
            FK are not smd.
            • mockingbird
              • Dec 2008
              • 5484
              For 16V 2200uF in 10mm diameter use either Panasonic FK or Samxon RS.
              RS is sold on eBay by a forum member here:
              http://www.ebay.com/itm/301167868355
              note: These are 3300uF and not 2200uF, but they will be just fine.
              If you want Panasonic FK, you can get them at Newark.
              EEVFK are SMD and EEUFK are through-hole. The ones I linked you to are through-hole.
              • jedwar10
                • Aug 2009
                • 43
                I very much appreciate the info.
                I think what I will do is use all Panasonic caps in the PSU using the FR series for all values except the 16v 2200uF 10mm where I will use FK instead.
                What do you think?
                  • 30932
                  sounds good, dont overlook any very small caps - those are the ones that can make it act dead.
                  you may not find FR/FK for very small caps.
                  if that happens then you can use panasonic FC or rubycon YXG or a few other good ones.
                  • Almighty1
                    • Apr 2014
                    • 222
                    FWIW, United/Nippon Chemi-Con has KYB 16v 4700uF 12.5mmx35mm which is made in Japan for a cheaper price which was what I used to fix a PC Power & Cooling Turbo-Cool 450ATX power supply recently, I was also looking at the Panasonic FR which has a lower impedance and ripple. Basically I Panasonic TS-ED for the 2x200v 1000uF Primary caps and for the secondary caps, it was a majority United/Nippon Chemi-Con KY/KYB and then Panasonic FR for the 50v 22uF, Nichicon PW for 10v 47uF, Rubycon ZLH for 25v 68uF, Rubycon YXJ for 50v 1uF, Panasonic FR for 25v 47uF.
                    Specs are as follows:
                    3140 ripple @ 100kHz
                    0.018 impedance @ 100kHz 20C and 0.072 impedance @ 100kHz at -10C
                    10,000 endurance hrs
                    • mockingbird
                      • Dec 2008
                      • 5484
                      The Panasonic FR are on sale for 0.72 at Newark. I doubt you can get KYx for less at Digikey.
                      • Almighty1
                        • Apr 2014
                        • 222
                        Hmm, $0.72 is cheap as when I was buying caps a month ago, the FR was $1.64 and the KYB was $1.31. Does Newark offer the same low price shipping as mouser and digikey?
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Yes, I believe so... The shipping to Canada used to be a lot, but a couple of years back they scaled back the waste in the shipping department and matched Digikey's $8 to Canada.
                          I usually use Digikey when I need the part fast, because Digikey packages often arrive overnight to Canada whereas I might have to wait a week for Newark and even longer for Mouser.
                          • ADV
                            Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                            by ADV
                            Good day everybody
                            I hope I'm posting in the right section - I am new to this awesome forum.
                            I have received an ACER Ferrari F-20" LCD Monitor to repair.
                            It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                            For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                            I opened the external 18V power supply and see no bulged capacitors...
                            11-02-2021, 09:32 AM
                            ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 03:28 PM
                            ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
