Capacitors in circut
  • Evenflow
    • Mar 2014
    • 38
    • US
    Is there any way to test capacitors, diodes,transistors in circuit??
  • mariushm
    • May 2011
    • 3799
    Re: Capacitors in circut
    You CAN measure in circuit, doesn't mean you'd get ACCURATE results.
    No matter how you'd measure, as long as it's in circuit, a capacitor will "interact" with other capacitors placed in parallel or in series with it.
    Lots of devices regularly have several capacitors in parallel to increase capacitance, decrease ESR and so on. Also, there are often low value ceramic capacitors in parallel with high value electrolytic capacitors, which helps due to the different properties of ceramic capacitors (but messes up the measurement).
    Transistors, mosfets etc can often have resistors between base/gate and other parts of the circuit, which can trick you into thinking the transistor is shorted or faulty in some way.
    Really, tools that advertise measurement in circuit really only mean to say they use a very low voltage to measure things, therefore there's very little chance they'd turn on a mosfet or transistor or diode (or whatever) and screw something up in the circuit.
    Again, they don't say the measurement will be correct.
    • Evenflow
      • Mar 2014
      • 38
      • US
      So unsoldering and testing out is only true way
        master hoarder
        • May 2008
        • 12175
        Yes.
        Key word here is "true way" because out of circuit there will be no doubt whether another component is affecting the reading.
        That said, you can often measure components in circuit AND get conclusive results most of the time (varies by circuit the component is part of), but you'll have to pay attention carefully to what other components may be affecting the reading of the component you are trying to measure. You usually pick up on that as you get experienced and test components in a variety of different circuits.
        The key to be able to do in-circuit measurements is to know the behavior of basic components very well and their typical failure mode. For example, resistors often go open-circuit, so if you do a in-circuit reading of a resistor, and it measures higher resistance than what is printed on its colors code (say much higher than 5%, that is... or whatever its tolerance is), then it is most definitely bad. However, if it's measuring lower resistance than what is printed on it, it likely isn't bad but it's not guaranteed (it could be open but maybe another component is pulling the resistance down across it, making it appear as if everything is fine).
        Similarly, diodes and MOSFETs often go short-circuit when they fail, and very occasionally leaky. However, if a diode appears shorted in circuit, see what else it is connected to it. If it's across a coil/transformer to clamp down inductive kickback, let's say, then you will be measuring across the coil as well, and that might trick you to think the diode is shorted when it isn't.
        BJTs can go short or open circuit (short most of the time, but not uncommon to go open either).
        Capacitors should ideally measure open circuit with a DMM out of circuit, but in circuit that's rarely the case. Measuring caps in circuits (except maybe very simple circuits) is usually not very meaningful. Measuring the voltage across them when the power is applied, however, can be.
        There's more to it than this. But like I said, some of it you'll pick up as you do more troubleshooting and a big portion is just analyzing the entire circuit and seeing what actually you can measure and conclude that you'll get a reliable reading.
        • mferna14
          26 LED Parallel Circuit
          by mferna14
          Dear Electronics Friends.,
          I have 26 LEDs (Rating 3v 20mA) in my garden attached all in Parallel Circuit. I am using a 12v 5amp DC power adapter. I calculated the value of Resistor which was nearly 13ohms 1 watt resistor. All LEDs light up very well.
          My question is after 4 ~ 5 days the first 2~3 LEDs (starting in the circuit) nearest to the power adapter get burnt or just do not light up & the rest 22 LEDs makes no difference, they glow very well. Why is this so? This is the 3rd time I have replaced the 1st 3 LEDs in the start of the circuit. Am I doing something wrong, or the...
          08-16-2023, 07:27 PM
        • samtron786
          Ceramic capacitors half short circuit or full short circuit?
          by samtron786
          Hello
          two small ceramic capacitors with values 040. Can you tell me
          whether they are half short circuit or full short circuit?
          Thank you
          01-07-2024, 05:20 AM
        • Fritter
          Power supply filter capacitor measurement in circuit
          by Fritter
          Hi
          Measuring a 400v 330uf capacitor across the bridge rectifier and in circuit with a multimeter on ohms. Measures 360 ohms both ways when polarity on the meter is changed. If this is normal, I'd like a brief lesson
          11-15-2023, 12:58 PM
        • vrasp
          Issues in PWM circuit with LC filter to drive Peltier
          by vrasp
          I've been trying to build a Peltier circuit that I can control with arduino and create cooling ramps. I've never built a circuit before and only have a basic knowledge of electronics.
          I've been researching how to do this and attempted to build it. My circuit is basically a PWM signal sent to a motor driver with an LC filter to smoothen the signal. Since very low temperatures are required, I added another Peltier on top of the first one. The top Peltier needs to be driven at a lower voltage to limit the amount of heat produced and effectively lower the temperature....
          10-27-2022, 08:11 PM
        • quickname
          Cyberpower 1500AVR UPS repair
          by quickname
          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
          I decided to verify that the batteries were...
          11-12-2023, 09:57 AM
