Help with Home Theather TZ215 Samsung
  • borism25
    • Mar 2013
    • Croatia
    Hi! guys i have a little bit of problems with this home theater...
    one day is just stop working and whan i open i saw bad caps, changed but nothing has start working. Than i saw a little spark on the resistor...after i change that the home theater has start working but i get really wierd noise from the trafo.
    http://www.pohrani.com/?1S/vY/1BDUexkl/img4637.jpg
    http://www.pohrani.com/?2i/Ox/YpI2qWv/img4640.jpg
    http://www.pohrani.com/?43/oN/4PXHVc15/img4642.jpg
    Whan i unplug speakers from the HT, and turn volume to 50 (max) i get the sound inside the HT...i don't know maybe something vibrate and get me the sound...a little bit of help a will be apricate it
    sorry for bad english
  • imp
    • Aug 2010
    • 125
    • Sweden
    Re: Help with Home Theather TZ215 Samsung
    Your pictures are far to small to even what it is .... Please post large, well focused pictures using the Attach files/Manage Attachments button below.
    • borism25
      • Mar 2013
      • Croatia
      i edit first post
        It is possible the sound is normal. Many SMPS transformers make noise. If the sound disappears when the case is installed, it could be considered a non-issue.
        • borism25
          • Mar 2013
          • Croatia
          After i plug the cable in to the power, i get that noise, and after power up HT 5sec i hier that sound, I see HELLO on display and just in that moment noise stop, after 2-3sec noise is get back. But if i turn the volume to the 0 (min) than noise is completly out i can't hear it. If i volume up on 1, i hear it.
          so in power off or power on i hear that noise, just once time today i didn't hear anaything, but why i don't know.
          What can impect on that SMPS transformers to reproduce something like that sound, bad caps, resistors ??
            Is it coming from the speakers, or perhaps from the coils near the class D output coils, instead of the transformer?
