Rubycon 6.3v 2700uf MFZ
  • Etouffee
    • Feb 2013
    I have 2 of these on my eVGA mother board that have bad caps. I believe it was a cooling issue over time that caused the problem.
    I did search and found this post that refer to the Rubycon 6.3v 2700uf MFZ 10mm.
    The post is about a year old and wanted to see if the same advice of a replacement would still hold true as it didn't seem 100% at the time. Here was the recommendation.
    Rubycon 6.3V 2700uF, MFZ 10mm, ??Ripple?? / ??ESR??
    ~seller not trusted~
    Try
    Nichicon 6.3v 2700uF , HZ 10mm, 3770 / 0.007
    http://www.mouser.com/ProductDetail/...mZ8C%252bg8%3d
    Thanks in advance for any reply's.
  • mariushm
    • May 2011
    • 3799
    Re: Rubycon 6.3v 2700uf MFZ
    Yes, the HZ will work.
    Keep in mind the HM, HN and HZ are discontinued meaning you soon won't be able to order them when they're out of stock. So if Mouser still has them, order them, otherwise don't count on Mouser restocking.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      https://www.badcaps.net/store/produc...roducts_id=149
      These will be just fine.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • LLLlllou
        • May 2011
        • 201
        Try
        MFZ are specialty OEM caps Rubycon makes and sells only to OEMs, and never published specs for. Judging by the fact that they are routinely used in the Vcore of Xboxes, and also going by the ratings of a single model posted in a Maxim data sheet, it's safe to assume they are better than MCZ, and either slightly inferior to, or equal to HZ. Either way, HZ is the only electrolytic that equals or exceeds the MFZ.
        If your MFZs died, heat may not be your only issue, a horrible power supply that's putting out horrific amounts of ripple is a likely co-culprit!
        As Topcat pointed out, he carries the HZ series and they are currently in stock:
        Definitely check for dead fans, clogged vents, etc. and pop open the PSU and have a look inside, odds are you'll have some more caps to replace.
          LENOVO ThinkStation E31 ThinkStation i7-3770 Specification for Upgrade or Repair
          This specification for the LENOVO ThinkStation E31 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation E31 boardview and ThinkStation E31 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-12-2024, 03:36 PM
