Seems like another compensation problem. As long as I threw away original caps some time ago, I dont know which ones are bad
So if anybody has it and could provide me with some kind of list of used small caps, I would be glad.
If not, I will demount it for components in soem point next week and continue with other projects I need caps for (I run out of RS 3300 uF/16 V for the time beig). I simply don't have the time to waste with these craps any more. And these FOrtrons became pretty much crap. Next time I know I have to both select small caps properly and test it after each step. I am still used to older FSP PSU's which werent so tightly set for these crappy caps.
The thing is, all of the small caps used this time are not so low ESR, some Rubycosn YXK or YK and Chemi-Cons KZG? pretty much egenral purpose. Msot of the original ones were tiny, so they couldnt have some super-low ESR values too. So I don't understand it.
So if anybody has it and could provide me with some kind of list of used small caps, I would be glad.If not, I will demount it for components in soem point next week and continue with other projects I need caps for (I run out of RS 3300 uF/16 V for the time beig). I simply don't have the time to waste with these craps any more. And these FOrtrons became pretty much crap. Next time I know I have to both select small caps properly and test it after each step. I am still used to older FSP PSU's which werent so tightly set for these crappy caps.
Half of the computer problems is caused by bad contacts
the id above.
