Re: BSOD and Gigabyte Capacitors
Thank you so much, mariushm.
I ended up finding the Nichicon HZ on digikey. 3300uF, 6.3v.
Thanks again all!
Rubycon MBZ would be kind of hard to find.
Panasonic FC might be a bit too low spec to replace those KZG.
The FM series from Panasonic is better but the capacitors are of larger diameter.
The FR series is meant to be a replacement for FM and it's thinner but taller than FM, which works great in your case. For anything under 1200-1500uF, the FR specs are worse than FM but for anything over they're much better. So again, it works great in your case.
Nichicon HM/HN are ok but you might be lucky to find HZ which is even better.
kzg: 3300uF 10x25 0.012 ohm 2800mA
hm: 3300uF 10x25 0.012 ohm 2800mA
hn: 3300uF 10x25 0.009 ohm 3190mA
hz: 3300uF 10x25 0.0065 ohm 4690mA
rubycon zlg: 3300uF @10v 12.5x25 0.013 2900mA https://cdn.badcaps-static.com/pdfs/...3bb75aa682.pdf
fc: 3300uF 12.5x20 0.038 ohm 1655mA (too low)
fm: 3300uF 12.5x20 0.018 ohm 2600mA (getting closer)
fr: 3300 @ 10v 12.5x20 0.018ohm 2600mA still not quite there
fr: 3300 @ 16v 12.5x30 0.013ohm 3630mA just right
The impedance must be lower or equal than what you initially had, the mA value should be equal or higher.
So as you can see from the values, HM, HN, HZ are direct replacement... diameter fits, impedance and ripple are almost if not identical.
If you can fit 12.5mm diameter caps in there, Rubycon ZLG also works, even though it's rated for 10v. Voltage doesn't matter as long as it's higher or equal than 6.3v
Panasonic FC as you can see is not really good enough, FM is close enough to say you can safely use it if you can fit it there.
But if you can fit 12.5mm diameter caps and the cpu fan doesn't block 30mm tall capacitors, you can safely go with FR 3300@16v which has better specs than KZG 3300uF 6.3v and furthermore, it's rated for 10.000 hours @ 105c - the Nichicon caps are only rated for about 4-6k hours.
You can get the Nichicon and Panasonic capacitors from Digikey.com or maybe from this site's store. Rubycon you can find on newark.com (besides the nichicon and panasonic)Last edited by mariushm; 04-10-2012, 06:18 AM.Leave a comment:
You can use Rubycon MBZ/MCZ, Panasonic FC, or Nichicon HM/HN.Leave a comment:
Thank you for the replies Hemingray and Rulycat.
I was able to read the numbers off the capacitors and was hoping to get recommendations on replacements:
- 3300 uF
- KZG
- 6.3V
- (M)105C
- 4(T)
- DD
Some of them actually had slightly different info:
- Some had 5(T) instead of 4(T)
- Some had 2D, DE, or 20 instead of DD
What is 4(T) vs. 5(T)? and the different two letter codes?
Any suggestions?
Thanks in advance!Leave a comment:
Some sources suggest they're Sanyo:
http://ee.gigabyte.com/products/page/mb/ga-k8nsc-939/
Others suggest perhaps they switched to KZG or similar:
http://www.newegg.com/product/produc...82E16813128286Leave a comment:
Yep, bulging caps = bad caps.
Pics would be good here. If some are bulging, all the others like it are likely also bad, best to replace them all at once. Some of the others can suggest a good capacitor type to replace em all with.Leave a comment:
I built a PC around 2005 for music recording and have used it extensively since then. It has never been connected to the internet and I rarely install new software on it. I configured it for music back on 2005 and left it be! (if it aint broke..)
So this past Saturday, it started BSOD (Windows XP, SP3) at random times. It would boot up fine and then suddenly blue screen. So I assumed a hardware failure given the information above. I went through the standard troubleshooting steps (replaced/moved around RAM, swapped video cards, disconnected all IDE except for main sata HDD, removed soundcard) all to no avail.
Finally, I inspected my mobo and found 7 bulging, leaky caps. Motherboard is a Gigabyte GA-K8NSC-939. Does this sound like it could be the problem? Worth trying to replace the caps?
Thanks!Tags: None
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
Channel: BIOS Requests ONLY!
Today, 09:15 AM -
- Loading...
