VA902b Shakey jittery image
  • blues
    replied
    Re: VA902b Shakey jittery image
    Do I need to connect this board to the power board and plug in AC to measure the DC here?
  • retiredcaps
    replied
    Circled in red are two voltage regulators.
    1) Measure the DC voltage of bottom 3 pins (ignore the fat tab). Use a ground screw on the logic board for ground (black probe).
    2) Report the part number and your measurements like
    Part number = AL1117-33
    pin 1 = 0.0
    pin 2 = 3.3
    pin 3 = 5.0
  • blues
    replied
    Pins 1 and 2 both read .0005 or was it .005 for both pins with capacitor in-line and power off. I have not yet getermined the readings with power due to my poor lighting. I bought a decent worklamp today, hoping to get readings tonight.
  • jetadm123
    replied
    If you find no issues with the power board, then I would suggest replacing the 6 caps on your logic board. Since these caps have a higher capacitance valure and are physically smaller, they tend to dry out more quickly.
  • retiredcaps
    replied
    Originally posted by blues
    Pins 1 & 2 are VCC5V. Do I touch the other end to GND pin 6?
    I prefer to use a ground screw closest to the measurement point. That way, there is no risk of both probes touching and possibly shorting out something.
  • retiredcaps
    replied
    Help can't find replacement cap for 100 uF 450V, anyone?
    Lots over at digikey, but before replacing any caps, what are your voltage readings?
  • selldoor
    replied
    Wouldnt worry about replacing if it doesnt look bulged or leaky the big ones are usually ok.
    If it becomes necessary we will come up with a suitable alternative.
  • blues
    replied
  • selldoor
    replied
    Yes - you can use 3 or 6 as ground
    Set meter on Volts DC - red (positive )probe on pin being tested Black (Negative) probe on gnd.
    Thanks for pics - mains pins look ok - trick of the light.
  • blues
    replied
    Thanks. Total newbie here, wondering how to test with my multi-meter. Pins 1 & 2 are VCC5V. Do I touch the other end to GND pin 6? Also more pics attached.
  • selldoor
    replied
    Hi - you have su'scon caps on the power board which is possibly the cause of unsteady voltages. Also on the back of the power board can you check the joints where the mains plug is - it just looks a bit odd in the picture - perhaps you can do a close up.
    I dont know if you have worked on open boards before but there are voltages in the region of 300-400 volts so you need to be careful.
    First can you measure the voltages at the connector at the top right in pic 2 and post your results. Then do it again with it all set up and working - take care that boards do not touch and you are working on a non conductive surface.
  • blues
    replied
    I followed your advice, but still experience a problem. None of the caps look bloated or leaking to me. Any suggestions of where to start? I have a 40W iron and a multi-meter. I have attached some pictures, I hope they are clear enough and that I have followed the requirments for uploading.
  • retiredcaps
    replied
    Is this possibly a bad capacitor problem?
    Yes, it could be. Take apart the monitor and have a look. Even if it is not, try reseating and cleaning every connector.
  • blues
    started a topic VA902b Shakey jittery image
    Newbie here, I have a viewsonic VA902b monitor that powers on and shows video output, but the screen looks shakey, jittery, like electrical interference. I chacked all cords and connections and replaced cords, all without resolution. Is this possibly a bad capacitor problem?
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
    09-06-2024, 10:56 AM
    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
