Fortron FSP400-60GLN failure modes
  • aym
    • Feb 2011
    Hi there, newcomer here. I hope this is the right forum.
    Is anyone familiar with the failure modes of the Fortron FSP400-60GLN ? I have a couple that have died after some years of 24/24 operation. The caps show *no* sign of bulging or leaking. No need to waste time recapping if it's usually the power transistor that goes...
    Thanks in advance.
  • puccovelli
    Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
    by puccovelli
    Hi all, I hope this is the right place to post.
    I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
    I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
    1] Could someone confirm what the component that has blow actually is (and where I could get another from).
    2] Whether this component is likely to cause the RAM failure issue, and if replacing...
    Yesterday, 06:30 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • ctroxtell
    Carrier HK50AA063 display controller common failure help
    by ctroxtell
    I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
    02-05-2025, 05:31 PM
  • howardc64
    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
    by howardc64
    Problem
    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
    Model & Board Pics
    Conflicting Spec
    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
    https://www.shopjimmy.com/vizio-gj-2k1...
    10-10-2024, 01:16 PM
